More volume = more volume to compress... so higher CR.mojogoes said:Costa...........more volume = lower cr = more boost........but there's only so far you can go before the start of injection/ignition becomes so finite that the fuel will not combust........this is why i now have my glow plug ignition on a manual switch for really cold conditions for one.
O meu mecanico vai manter a stock de 3 moscas.... a minha duvida era se meter uma de 2as moscas tem alguma vantagem para aumentar a compressao.choramix said:a junta de cabeça escolhes quando medires a altura do piston no tdc em relaçao ao bloco se tiveres duvida nisso mandote bonecos para veres que é mais facil
NopArturCosta said:Wow very nice pdf
About the CR... it will become higher since there is more space to fill... isnt it?
ArturCosta said:O meu mecanico vai manter a stock de 3 moscas.... a minha duvida era se meter uma de 2as moscas tem alguma vantagem para aumentar a compressao.
Cumps
Please use your brain.. there antoher topic where I must have said more than 10 times how it worked before people were actually understanding it..Silva said:Nop
OEM 19-1 ....now will be something like 17-1 ,I think ...
Is better for higher Hp
Keep on going
So what?Rub87 said:Please use your brain.. there antoher topic where I must have said more than 10 times how it worked before people were actually understanding it..
Increasing the bore without touchin anything else will INCREASE the compression ratio, but probaly the bowl will have a slightly larger volume..
Sim , acabei por esconher a caixa muitio pela info que me tinhas dado , pqchoramix said:e isso so da com a junta e a cabeça apertada.
p.s boa sorte ai com a a4
ja reparei q espetaste a caixa ajm que te tinha falado na altura
Yes the head will be skimmed as far as I know.. althought it was ok it ran 343kms ... it was "closed" for 12yearsmojogoes said:Take some pic's Costa while its all apart........did you have the head skimmed just as a precaution.
The engine will run at idle for 1day more less... then I will be gentle in the first 500kms of the engineRedputter said:When you get it back together, try to keep the engine speed down if you can. That will put a lot less stress on all your rotating parts.
