Old November 18th, 2017, 15:51   #1
ntiguy85
Default Bad BP fuel costing $3200+ HELP!
Lengthy post..but i NEED HELP. I filled up at a BP station and drove about 5-10 miles that evening and next morning and the car (2015 Jetta TDI) cut of driving down the road and that was all she wrote. I had it towed in and the dealership tested the fuel first after contacting VW reps and found the fuel was contaminated. Drained and cleaned fuel tank, flushed fuel lines, replaced fuel filter, chemically cleaned injectors, 5 new gallons of fuel ($800). Car didnt run. Was told the high pressure pump was bad due to bad fuel and it ruined it. Replaced HPFP ($1700). Car didnt run. Car then had fuel pressure but not enough to run. Was then told that the bad fuel also ruined the fuel rail and fuel pressure regulator. Replacing that now ($750). Thats $3250. Did i mention the car is out of warranty? FML!! Im livid and want some advice. I have contacted BP and filed a claim but they stated that i still have to pay out of pocket for the damages and send in the required docs before they will start to investigate and then decide (after a min of 45 days) if they will pay for the damages ensued by their bad fuel. I am a prior ford mechanic and know my stuff but this seems to be parts replacing at this point. I would like to know if anyone has any thoughts or advice on what could be next if i find out Monday that it still doesnt run or if anyone had had bad fuel in a 2.0 CR and experienced anything like this.
ntiguy85 is offline   Reply With Quote
Old November 18th, 2017, 15:54   #2
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Search "HPFP failure". Happens a lot.
Your comprehensive insurance may cover the incident also.
Yeah, that fix is costly as the high cost fuel system parts go south.
Good luck!
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old November 18th, 2017, 16:31   #3
ntiguy85
Thanks aja888! ill look that up right now and read some.
Old November 18th, 2017, 16:40   #4
aja8888
aja8888's Avatar
Save you some time:
http://forums.tdiclub.com/showthread...t=hpfp+failure
Old November 18th, 2017, 22:48   #5
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
Sorry to hear!
Is the BP station located along a major route and get a lot of diesel truck traffic? If not, the HPFP may have become another victim of water ingestion from condensation in the fuel.
The fuel at stations that rarely get any diesel truck traffic can be months old and pick up a lot of water and have microbial growth due to the water. A single tank of water contaminated fuel from a station that rarely gets any diesel truck traffic is all it takes to do a lot of damage in a very short time. This is why I say to fuel up ONLY at high diesel turnover stations along major routes to avoid getting a tank of watery fuel. Go where the big rigs go to fuel up.
Sorry to hear. Good luck.
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Old November 20th, 2017, 06:42   #6
belome
Fuel Economy: 47'ish
How many miles on the car?
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old November 26th, 2017, 00:03   #7
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
How many miles are on this car? I'm actually surprised you are out of warranty (did you not do ANY of the emissions fixes??) AND beyond that, if you have documentation that it was the fuel, bought from the BP station, they should be 100% on the hook for this.
Mrrogers1 is offline   Reply With Quote
Old January 13th, 2018, 12:31   #8
Mrrogers1
Did you ever get this resolved?
Old January 14th, 2018, 09:09   #9
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
Curious as well. The OP says HE fuelled up. His problem sounds more like he mistakenly filled up with gasoline. That's what it sounds like to me, drove home and next morning the car stopped on him.
I've been driving Diesel cars for over 25 years and have filled up all over N.A including Mexico and have yet to experience real bad Diesel. At least none that stopped me right away.
On a past 1995 Passat TD I was lacking power and the cause was a very clogged up fuel filter, probably picked up from several contaminated fuel fill-ups.
My .02 worth
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar.
Jetta_Pilot is offline   Reply With Quote
Old January 15th, 2018, 07:28   #10
The Tortoise
I doubt it was filled with gasoline on account of him driving 5-10 miles before it died.
The Tortoise is online now   Reply With Quote
Old January 15th, 2018, 09:34   #11
Jetta_Pilot
Au contrare, exactly what you would get from the fuel in the lines and filter before enough gasoline would come down the pipes to effectively shut the engine down!
Old January 15th, 2018, 10:20   #12
tdiatlast
^^^this...
Where oh where is the OP?????
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old January 15th, 2018, 11:09   #13
The Tortoise
Huh, good to know.
Old January 16th, 2018, 20:59   #14
Ol'Rattler
Ol'Rattler's Avatar
Wrong. if it was topped off on an almost empty tank it might only go about 3 blocks if filled with gas. Remember that fuel is continuously being recirculated back to the tank and mixing with what ever is in the tank.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old January 17th, 2018, 04:04   #15
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
Does the 2015 Jetta recirc to tank from filter? The CRUA doesnt.
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Bad Batch of BP Gasoline jbright General Automotive 0 August 21st, 2012 16:13
fuel economy costing me tires???? grizzlydiesel TDI Fuel Economy 10 March 11th, 2010 14:34
Engine surging above 3200 RPM related to fuel? AZ TDI'er Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 10 January 15th, 2008 20:24
RC3 costing fuel economy? downcycle TDI Fuel Economy 7 May 13th, 2007 18:30
Bad luck with BP??? Polar_TDI TDI Fuel Economy 12 January 19th, 2006 21:44
Page generated in 0.15333 seconds with 11 queries
[Output: 129.85 Kb. compressed to 108.27 Kb. by saving 21.58 Kb. (16.62%)]
