Old October 24th, 2017, 12:47   #1
Lou Como
Default One to two year-old diesel fuel in tank of "new" 2016 GWS TDI
I'm supposed to take delivery on my 2016 with 50 miles on the odometer. It's a Mexican car originally destined for the US, and has been in limbo because of dieselgate. As far as I know, the fuel could have been in the tank for a year or two.
Problems? Suggestions?
I was thinking I'd add a diesel fuel stabilizer, or perhaps a different additive?
Drain and refill the tank?
Lou Como is offline   Reply With Quote
Old October 24th, 2017, 15:14   #2
Lightflyer1
Lightflyer1's Avatar
I wouldn't. Supposedly they were being taken care of. Ask the dealer about what they did if anything for the fuel. I did nothing to mine when I got it a few months ago. No issues.
Old October 25th, 2017, 05:53   #3
Lou Como
Thanks for the advice. Another forum member reported his "new" deiselgate car ran well after sitting around for a year or two.
Old November 4th, 2017, 05:38   #4
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
A year of sitting won't do a darn thing to diesel fuel. Drive more, worry less.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old November 4th, 2017, 08:04   #5
tdiatlast
Hmm...since diesel is highly hygroscopic, sitting for a year would give ME concern, especially since it's doubtful the car sat with a FULL TANK of diesel. It probably had only enough fuel to jockey it on/off transport vehicles.
Unless VWoA did the right thing and fully drained/siphoned the tank, I would be concerned about residual water. The fuel filter is supposedly designed to keep water molecules from passing through, and residual water will settle to the bottom of the FF canister. If it were my car, I'd check the canister after burning through a tank or 2 of fuel... but hey, I'm OCD!!!
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old November 4th, 2017, 08:56   #6
flee
Fuel Economy: 40-ish
It's no more hygroscopic than the oil in the crankcase. Are you thinking of gasoline?
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old November 4th, 2017, 09:00   #7
turbovan+tdi
turbovan+tdi's Avatar
Diesel can sit for years and years and years and years and years with nothing happening to it, as said above, drive more, worry less.
If you want, add some white bottled Power Service.
Old November 4th, 2017, 12:55   #8
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
while obviously less susceptible to water issues than a CR, ive had tractors sit with diesel in them for nearly a decade... new battery, prime the pump and start doing field work.
Ive also bought my B4 that had sat for 8 years. Got it running in spring and it ran fine all summer but had to drain and rinse the tank once winter came because the tank was full of algae looking gunk that gelled in the filter when cold.
End of the day, its your ride and your peace of mind but 1-2 years wouldnt bother me any.
2003 Jetta TDI - 11mm IP, R520s and FMIC from the Red Death, HE221W (shooting for 26PSI), 1.8T pancake, DIY 3" OMI, still working on the DIY tune... its a learning process.
1996 Passat TDI - "Red Death" RETIRED. Had: Malone stg 1, 11mm IP, R520s, GT15/17 hybrid, FMIC, ETC
1997 Passat TDI wagon - Running donor or beater for sale, rough body
ketchupshirt88 is offline   Reply With Quote
Old November 9th, 2017, 08:45   #9
740GLE
That and add a bottle or two of dry gas if you're really concerned
740GLE is online now   Reply With Quote
Old November 16th, 2017, 19:45   #10
AndyBees
AndyBees's Avatar
I know it is not a common rail .. but, I'm wringing my hands over the 10 year old Diesel Fuel in my RV (5.9 Cummins) ... same thing with my Yanmar Excavator and Dodge 5.9 Cummins Pick-up that I do not drive very often.
I have about 10 gallons of Diesel Fuel from the Katrina Era (hint: 2005). It still looks like and smells like Diesel Fuel.
Lastly, what about those cars that sit on car lots for months and months........ surely that fuel is old and no good! Hmmmm.
As Turocharged798 said, drive more and worry less!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old November 18th, 2017, 08:19   #11
Lou Como
Well, VW de Mexico did syphon the tank. I know because it was delivered to me bone-dry.
I'm loving the TDI, the forced-induction and big torque is perfect for high-altitude mountain driving.
Old November 23rd, 2017, 20:32   #12
rrgrassi
rrgrassi's Avatar
Fuel Economy: 46 city 53 hwy
Diesel is a light oil, not a distillate like gasoline. It can sit for years with out any issues. That said, any moisture present, and a fungus can develop. Add some biocide found at any marina to kill off any potential fungus. Make sure you have plenty of fule filters as well.
RRGrassi
06 Jetta TDI BRM 248K
03 Golf TDI ALH 380K+
90 Dodge D250 Cummins 12V 400K
rrgrassi is offline   Reply With Quote
Old November 27th, 2017, 01:18   #13
[486]
TDI(s): 02 golf ALH
it's already sat for years
if it had algae in it the problem is well and over with by now
you'll notice black schmutz caked fuel filters if that's the case. Warranty should cover it.
[486] is offline   Reply With Quote
Old November 27th, 2017, 04:09   #14
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I have brought diesels back to life that had been sitting for years (like, over a decade in some cases), and they had no issues with the fuel. I just filled the tank the rest of the way up with fresh fuel and off they went.
Gasoline is a VERY different story. That stuff starts to go bad in weeks, and gets downright rotten in months.
oilhammer
www.cardocautomotive.com
Old November 27th, 2017, 09:30   #15
RabbitGTI
RabbitGTI's Avatar
Fuel Economy: Don't know. I just feed it and drive.
Kinda off topic, but I pickle my snowblower, mower and track car with Sta-Bil. Does it really work or is there something better? I've never had any problems after six months or so of sitting.
Rabbit GTI racecar RIP, 84 Rabbit GTI, 88 Golf GL, 97 Passat TDI, 07 Jetta 2.5, 02 Beetle 2.0, 08 Jetta 2.5 with Aisin Box.
RabbitGTI is offline   Reply With Quote
Anyone have any information on the "revised fuel tank"? Paging DaMidget and Fixmy59.. JM Popaleetus VW Passat Family (NMS and B7) TDIs (2012+) 72 June 10th, 2013 12:47
Ideas for TT TDI "diesel fuel only" cluster foil, fuel door sticker? Redneck Truck VW MKIV-A4 TDIs (VE and PD) 3 October 2nd, 2012 18:00
02 Golf TDI in-tank "fuel pump" function? triumphx1 Fuels & Lubricants 11 January 1st, 2008 15:56
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 06:06
5w-30 diesel oil named Lubricants World "Product of the Year" TooSlick Fuels & Lubricants 27 July 25th, 2002 00:46
Page generated in 0.17707 seconds with 11 queries
[Output: 130.73 Kb. compressed to 109.17 Kb. by saving 21.55 Kb. (16.49%)]
