Old October 26th, 2017, 20:50   #16
3L3M3NT
3L3M3NT's Avatar
I figured I'd update this thread after taking the car to the track 2 weeks ago. I decided to go with the Schaeffer's 5W-50 S9000 oil. The car ran great during the track day and the only problem we had was not related to the engine getting too hot.
The highest temperature we saw on the gauge 148 F this was on a cool fall day was in the low 50s and ended up raining after the 2nd session, so that probably helped to keep the temperatures down a little bit. I still don't see there being a huge increase in temps during the summer months and as long as they don't get over 220 F I don't see a reason to slow down or pull of the track and head back to the pits.
I can update this again next summer if anyone is interested.
Sturgeon Bay, WI Cruise/GTG October 20th, 2018
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
3L3M3NT is offline   Reply With Quote
Old November 1st, 2017, 15:40   #17
TooSlick
TDI(s): Audi 100S
You sure the oil temps were only 148F? That number sounds VERY low for any fully warmed up engine, even under easy street use. Does your engine have an OEM thermostat? What temp does it open at?
Thanks,
TS
TooSlick is offline   Reply With Quote
Old November 3rd, 2017, 19:53   #18
3L3M3NT
3L3M3NT's Avatar
Thanks,
TS
To my knowledge it should be the factory thermostat installed in the engine, but I can't say that 100% certainty. It's reading off of an aftermarket relocation kit, so that is probably part of the reason why it's reading so low imo.
http://store.42draftdesigns.com/VW-O...Kit_p_314.html
I'll have to keep an eye on it and see what happens when things get warmer next year.
Firefox fix
RTDI Build Thread
Old November 4th, 2017, 08:58   #19
xjay1337
148F is 64c. So this is not correct.
Both my old PD and CR natural oil temperature would be around 95c. Which is over 200F.
The max temp I run to is 125c / 257F and even with an oil cooler I can hit that quite quickly.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old November 4th, 2017, 13:06   #20
TooSlick
TDI(s): Audi 100S
I was thinking it's probably reading 148C, which is ~ +300F? Of course that would be VERY high for an equilibrium sump temp.
Old November 6th, 2017, 07:02   #21
xjay1337
Possibly. At those temps I suspect the water temperature would be very high too.
I am starting to find the stock limits with my coolant temperature hovering around 102-103 on trackdays even with oil cooler. A better radiator I think is needed.
Race to and from Austin for 'the race' never better than in a TDI. S-tdi-gg Road Trips 2 March 30th, 2015 07:17
Got a race pipe, but found oil on the old parts.. problem? rdsteen TDI 101 1 March 14th, 2010 12:50
Size of the Race Pumpe Duse Injectors / Race PDE RTDI-Tom TDI Power Enhancements 34 October 23rd, 2008 17:48
Race pipe, CC vent, oil leak @ intercooler. Overboost Looking for advice Plastico Malo TDI 101 3 December 18th, 2007 10:08
Soot + Oil=Soilt intake (Race Pipe) meshplate TDI Power Enhancements 4 October 10th, 2002 17:36
Page generated in 0.13858 seconds with 13 queries
[Output: 80.12 Kb. compressed to 70.73 Kb. by saving 9.39 Kb. (11.72%)]
