shawnmeadows
On my 2013 tdi sel the lights worked in auto setting, but not working in same setting on new 2014 tdi sel...owners manual says should work, dealer says no...anyone else have this problem
Checked is correct. Unless new versions are polar opposites? the adaptive light refers to the auto position of the headlight switch.Thanks Norm.
Byte 17 bit 0 was set to 1/checked already - I unchecked it and will check tonight to see if it's working.
I feel the same about the foglights - have to switch the headlights to 'on' to be able to turn them on (euroswitch installed). Would have been a simple change to allow the switch to pull out in auto.No help from VW they say they should work one day and they should not the next, this really sucks if they can't make them work, who wants to turn lights on manually every time you need to turn...kinda why I bought a sel, liked this option because we have no street lamps in the area I live
Sounds like you're wasting your time trying to work this through your dealer. Either buy/borrow a VCDS, or find a Trusted Guru and have your car scanned, and follow the instructions from vw_norm. Until you do that, we have no way of determining what the issue is.No help from VW they say they should work one day and they should not the next, this really sucks if they can't make them work, who wants to turn lights on manually every time you need to turn...kinda why I bought a sel, liked this option because we have no street lamps in the area I live
Shawn - Seth in Dallas reports that his 2014 windows remote down with the keyfob in this thread: http://forums.tdiclub.com/showthread.php?t=405848Vw called and claims they now have a fix for all the 2014 passats with static cornering lights...will make them work like 2013 model, they will operate in auto setting now...that's great pretty useless the way they are now
Mine work in auto mode, its a 2014 took delivery last week. Build date 12/2013.Vw called and claims they now have a fix for all the 2014 passats with static cornering lights...will make them work like 2013 model, they will operate in auto setting now...that's great pretty useless the way they are now
Does this rectify the 2014 model issue where cornering lights don't come on in AUTO?Byte 14, bit 7 - cornering lights via front fogs active
Byte 17, bit 0 - adaptive light/cornering light variant (0=cornering light/1=adaptive light)
Byte 17, bit 4 - assistance driving light (auto mode)
should all be checked on. Key bit to check here is byte 17, bit 0 as this tells the bcm to engage cornering lights with the switch in auto - adaptive.
also check Byte 26, bit 6 to turn on cornering lights when in reverse.
I went out and checked my 2014 SEL Premium this morning - all bytes are set as indicated above, however the cornering lamps still only work when headlights are "On", not in "Auto".Byte 14, bit 7 - cornering lights via front fogs active
I wonder if it's a BCM firmware flash?
Nothing yet, DZ was going to compare scans and go from there. Might be a different part number or coding. What's your build date? Just wondering if we can narrow down the change to a build date. My build date is 12-13.D-Cell_Mecanick: any update on the comparison with dzcad90? I have a '14 that operates in the same way as his.
Sent from my SCH-I535 using Tapatalk
