dogder
Hi all! This is my first post (just joined yesterday). This is a great website and have used it often. Thanks for everyones help!!
So here is my problem (yet another limp mode problem):
My 2000 Beetle TDI has been in and out of limp mode for sometime. I've looked at the majority of the posts including Canadian Grizzly. I helped a friend change the turbo on his 2000 Jetta TDI and he gave me his old turbo. I had it overhauled and the actuator repaired by Turboworks. I installed this turbo, cleaned the intake, EGR, pipes, intercooler and snow screen. I changed almost all the vacuum hoses. I recently purchased a Ross Tech Vag Com. The error code is 17964 Charge Pressure Control - Negative Deviation P1556-35-10 Intermittent. I did check the operation of the N75 using the Vag Com (OK).
If the N75 works using the Vag Com, can I assume the vacuum system is ok??
If the MAF sensor is bad, will it throw a code??
Anyone have any ideas??
