86Vanotdi
Hello All,
This is my first post on the forum. I'm in the final stages of a FAS (forigen auto supply) GEN.V turn key diesel engine install. I'm going to need some direction for working with an OBDII/ VAGcom system. The instructions state that I will need to erase initial start up codes and preform basic functions of throttle body adaptation. The FAS GEN. V system uses VAGcom specific or equivalent VW style (5051-5052) scan equipment. Everything I just stated was directly from the instructions that come with the kit I've installed.
My only other conversion was a Subaru OBDI 2.2 so I'm not familiar with using scan equipment. So the help I need is to determine what scan equipment I need and what to expect when I turn the key for the first time.
The engine is a BSW 1.9 SOHC Pumpe duse. BSW on ASZ injection with DBW. I don't realy understand any of those letters but I was asked those questions by another source I was getting guidance from.
Anyone with advice would be great to help me get my conversion running. Thanks , GreggK
