Drivbiwire
Zehntes Jahr der Veteran
- Joined
- Oct 13, 1998
- Location
- Boise, Idaho
- TDI
- 2013 Passat TDI, Newmar Ventana 8.3L ISC 3945, 2016 E250 BT, 2000 Jetta TDI
DLC 1019 and DLC 520
ALL of our nozzles are BRAND NEW, never mounted units and are 2010 production nozzles!
These nozzles come with a 5 year unlimited mileage warranty when mounted by us and when used with ULSD fuel following only the published VW maintenance guide (fuel filter every 20K).
All Nozzles come with the original Bosio Provided LOT ID# to certify authenticity and are provided to you along with the original packaging.
All new T4 DLC nozzles come with a 5 year unlimited mileage warranty when installed and balanced by us!
Note: Warranty does not apply to damage caused from the use of more than 20% Biodiesel or other non ULSD fuels (Off-road, WVO/SVO, Homebrew fuels).
We offer custom flow settings at no additional charge and insure a flow tolerance of less than 1% (Typically .5%) on every set we mount! No more guessing how the injectors are going to run, perfectly smooth linear power all the way to redline and NO MORE SMOKE at start-up!
These nozzles will easily support power in excess of 150HP and with the un matched durability that cannot be gained from the older late 1990's T4 non DLC nozzle design!
In addition we have the new 520DLC's also that come with a 5 year unlimited mileage warranty!
T4 DLC nozzles are $360 per set plus mounting
520 DLC nozzles are $310 per set plus mounting
PM us for details, no worries these offerings are here to stay and are the latest in Diesel Nozzle technology, so don't settle for "Remounted" when you can have GENUINE brand new 2010 generation nozzles.
