Drivbiwire
Zehntes Jahr der Veteran
- Joined
- Oct 13, 1998
- Location
- Boise, Idaho
- TDI
- 2013 Passat TDI, Newmar Ventana 8.3L ISC 3945, 2016 E250 BT, 2000 Jetta TDI
Mickey what we are resetting is the timing of the cam as it relates to the crank thats all. The injection timing is another setting unto itself. Think of the order this way Set the cam and crank timing then set the injection timing. Because of the relatively short distance between the crank and cam pulley the amount of stretch over the life of the belt won't change it much, but since the length of belt will only vary a small amount they used the compression fitting on the cam to compensate for lets say a half tooth off. This way the cam and crank are in perfect timing thus the reason they used such a short run between the crank and pulley.
DB
DB
