icecap
- Joined
- Apr 10, 2007
- Location
- Chilliwack & Mission BC
- TDI
- 2006.5 Jetta TDI 5Spd Black Anthracite Pkg 1
I haven't posted for a long time but have an issue and could use some advice from someone who has done this procedure. I've had an intermittent problem with the indicator light warning of a burned out bulb coming on then going out again for months and could never find a burned out bulb.
The bulb has finally burned out and stayed burned out. I found it was the small marker light bulb that is mounted inside the headlight assembly through the side of the high beam reflector housing of my base model Halogen headlight assembly. By the look of it it looks like it could be a real bear to access and change. I've had to replace the headlight bulbs several times but never that small bulb. Have any of you changed that bulb, if so did you have to remove the headlight assembly from the car to get at it?
Is the bulb number the standard 2825?
Thanks for any advice.
Solved, it wasn't that hard and covered in owners manual.
