Old January 29th, 2018, 21:54   #31
lexi.kiselev
A bit of an update.
I haven't had much time to work on it but i did get some stuff done.
I got most of the suspension done, just have to hook up the brake lines and finish putting the steering links together. ill post some pics later
I decided to redo my engine bay since i half ass'd everything because i was too excited to get it running. The goal is to make it look nice and pretty.
Modified the intake manifold.
Untitled by lex kiselev, on Flickr
Decided to put a new intercooler in the front.
Im going to place the battery back into its original spot on the passenger side. Im also installing the stock tdi air filter box, hoping that will quiet down some of the engine noise. I bought an original power steering reservoir and extended it. Also removes the tdi expansion tank and going to install the original Toyota one.
lexi.kiselev is offline   Reply With Quote
Old January 30th, 2018, 05:57   #32
vtpsd
Fuel Economy: 45mpg avg
I hate be be a bummer, but I have that exact intercooler on my audi 90 with and AHU swap. The packaging is perfect for a longitudinal TDI, but it doesnt work very well. It heat soaks very quickly and intake temps get pretty hot.
A friend also had one on an audi 4000 with a 20vt swap and a big turbo, and experienced the same thing, very fast heat soak.
current: 03 jetta wagon (pp520, malone stg3, straight pipe), ford tractor with saab turbo, Snarling Audi 90q AHU swap (holset he211w, 32psi, race 520's)
past:11 second audi 90 20vt monster, 20vt swapped audi 90 winter beater, 10vt swapped 4kq with efi and many many other 5 cylinder audis, and a few 1.8tq's
vtpsd is offline   Reply With Quote
Old January 30th, 2018, 07:04   #33
jimbote
jimbote's Avatar
vtpsd, do you think this intercooler is an inherent bad design ? maybe heat soaks because of the large tank to core ratio ?
jimbote is offline   Reply With Quote
Old January 30th, 2018, 07:36   #34
vtpsd
I think its a combination of a less-than-ideal design combined with a cheapo core. I've seen where people have fabricated an intercooler like this with a good quality core, and they work decently well.
Old January 30th, 2018, 09:30   #35
lexi.kiselev
Bummer, i guess ill just run it for now until i can get something decent.
Thank you for the heads up vtpsd
Old January 30th, 2018, 11:15   #36
vtpsd
Obviously, it will work fine, but take a look at your intake temps after a few seconds on boost and see if they start to climb.
I was so damn limited on front end space, and I basically built a cross member around this intercooler and radiator setup, so I havent changed it. I would if I could though.
Old January 30th, 2018, 15:16   #37
lexi.kiselev
Vtpsd,Are you running and fans behind your IC?
Old January 31st, 2018, 08:21   #38
vtpsd
The intercooler is the first, then the radiator is behind it, and the radiator has puller fans. The intercooler has great airflow on my car.
Old March 13th, 2018, 00:40   #39
lexi.kiselev
Wink
Little Update:
I ended up getting a new intercooler, its a spearco clone. I looked inside of it and i could see that the fins were staggered unlike the previous one.
The reason for getting the new one was because i found that it was leaking from two spots.
I got the runner under its own weight and its semi drive-able.
I took it for a spin and got really bad death wobble. It looks like either its a bad wheel bearing or trunnion bearing, because I wiggle the tire up and down while the axle is on jacks stands
I should have rebuilt the dam thing in the first place...
I still have the boost spike and surges.I also get black smoke if i step on it on idle.
I decided to put the old 2.5bar map on and the smoke went away and so did the surge, however the actual boost is still way above requested in my log
When I run my scangauge and look at boost, it only reads up to 22.5psi
Could it be that my tune still has a 2.5bar linearization?
OH and heres a pic
Old March 13th, 2018, 18:39   #40
Owain@malonetuning
Looking good!
The tune update 3/16/17 was for a 3 bar, you have a fairly normal stage 4 tune. Since you have the 2.5 bar in the scangauge can only read as much as it puts out. Might be worth sending along some logs and picking up a flashzilla, happy to help there.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is online now   Reply With Quote
Old March 13th, 2018, 23:41   #41
lexi.kiselev
How does the flashzilla work? Would I have to buy a new tune again?
Old March 14th, 2018, 11:53   #42
Owain@malonetuning
Nope, you've already bought one.
It's pretty straight forward
• download software from www.malonetuning.com/fz
• plug in the device and hit link
• select your vehicle from the listing
• plug into your vehicle and read off an ECU file
• plug into your PC, load the program and hit "read ori"
• email us that ECU read, and we'll reply with a tune
• press "upload mod" to upload the file
• plug the device back into your vehicle and go through the tuning menu to install it
Feel free to shoot me an email if you have any other questions.
Old March 14th, 2018, 21:01   #43
A-man930
Lookin' good!
A-man930 is offline   Reply With Quote
Old July 21st, 2018, 14:02   #44
lexi.kiselev
Long overdue update...
Ive been getting some crazy death wobble with the stock fj80 radius arms.
I was going to do a 3 link eventually in the future but didn't want to throw down alot of $$ at the moment.
ive decided to do the three link and be done with it.
I purchased a 3 link kit from Ruffstuff and bought some used 12" fox coilovers from craigslist and it all went from there.
fast forwad to now, ive been dialing in the 3 link and finally got it to where i can drive it on the freeway. Now i can do some logging so Malone can adjust my tune.
Im still in the process of figuring out the overboost. I have installed a boost valve and i am still getting overboost
My guess is that it has something to do with the turbo/actuator?
TDI 4Runner tdi4runner TDI Conversions 28 November 13th, 2016 21:04
IQ is way off after sitting 1.81, 1.88, -1.86, -1.88 DougInFL VW MKIV-A4 TDIs (VE and PD) 25 July 21st, 2015 15:53
88 4runner - ALH Danielg42 TDI Conversions 140 February 27th, 2013 11:59
RBX 88 4Runner Diesel Swap RBX TDI Conversions 32 April 25th, 2011 05:00
TDI into 4Runner? RoundHouse TDI Conversions 19 July 21st, 2006 18:14
Page generated in 0.18953 seconds with 13 queries
[Output: 122.16 Kb. compressed to 102.92 Kb. by saving 19.24 Kb. (15.75%)]
