relumalutan
While I drive, if I open the sunroof or I crack open any window, the car fills up immediately with exhaust fumes. I believe the smell comes through the HVAC vents. Otherwise, if I drive with the sunroof and windows closed everything is OK. Is this the famous EGR cooler valve leak? Any way to inspect it or to identify the symptoms without going through the pain of removing the Dieselgeek panzer plate and the factory belly pan? VCDS scan returned with no errors, and I cannot really hear any hissing noise. Thanks.
