chimmike
So I posted this back in January and it's rearing it's ugly head.
This is mainly on driving trips of 2hrs or more. What happens is the vents internally close very slowly, limiting the air discharge from the vents. The odd thing is the fan remains at the same speed (I.E. I can hear it at the same speed). If I shut the system off for 10 mins, and restart the fan it'll come back to normal, the fan will blow normal speed thru the vents. but again, the airflow will slowly decrease after a while.
is there a solenoid or something internally that could be failing? I mean, if i set the system on auto, the fan speed will increase but the flow won't because the vents just aren't allowing it through.
And the sensor is hot (the one on the dash) because the sun is shining right on it.
It's gettin to ticking me off, this HVAC system. I mean, when I shut it off, if I want the windows open, I can't just shut off the system and put recirc on, it ONLY allows recirc on when the system is on. I love the car, but I think the HVAC system was poorly designed with too much internal control for no reason whatsoever.
And since summer is coming and I'll be on the road for work a lot more, I NEED this figured out. I can't run in the car on the interstate with the a/c off for 10 mins at a time in a suit while the damn system resets or whatever! HELP!
