HoneyBeetle
Just wondering if anyone has any idea how to release or "open" the driver's side seat on an 01 New Beetle so I can do stuff under the seat?
I need to check some wiring under there to see f the wires are broken or disconnected.
I'm rying to figure out how best to approach this to fix an airbag code that said there's an intermittent or otherwise bad connection. I'm not going to spend too much time outside, so I'm doing my homework indoors first.
Note: I noticed the wiring harness, or wire assy is yellow, if this helps. All I need is to lift the seat bottom, somehow, to get to it.
Maybe someone knows what I'm talking about. If not, I'll try to take pictures to illustrate.
