frugality
The DPF essentially blocks the exhaust. It's a porous ceramic block. So no soot will go THROUGH the ceramic unless it's cracked. If my DPF's ceramic is 100% intact, and if I'm seeing soot, then the only other possibility is that the ceramic isn't well sealed around the perimeter, and I'm getting a little leakage/blow-by.
I have on occasion smelled a wee bit of diesel exhaust at cold start-up. I always attributed that some sort of small leak at a joint before the DPF, but as I consider it now....there probably isn't a place for it to leak ahead of the DPF, except the exhaust manifold gasket (?)
