Instead of starting a new thread, I decided to revive this old thread and add to the conversation.
I am certain that there are more TDI owners out there concerned with improving their fuel economy yields.
My annual commute is about 21,000 miles and the main reasons why I purchased the TDI were: fuel economy, practicality and torque
I also love long distance road trips!
As the tires on my factory 17 inch Portos wore down I started looking for alternatives. I realized that a high ranked set of 225/45/17 or similar size tire will set me back anywhere between $700 and $800 (before any rebates) installed locally in the SF Bay area.
I found a set of reasonably priced steel wheels from a 2013 Golf in 195/65/15 with around 5000 miles on them and bought them from a fellow VW Golf owner.
The emergency spare that came with my 2011 TDI was 15 inch in the same 195/65/15, but with a lower T speed rating. I installed the 15 inch steelies in an effort to avoid spending so much on new tires for the 17s.
What was immediately noticeable:
- improved ride (likely due to the taller tire side wall)
- less steering effort while parking
- less tire noise (but I attribute this to worn out Conti Extreme Contact DWS vs near new Conti ProContact)
- a noticeable amount of dive in spirited cornering (also due to taller and more flexible side wall)
- significantly better fuel economy (initial test over 600 miles yielded 4mpg better than same route on the 17 inch Portos).
By the numbers:
The 15x6 inch steel wheel, stock hub cap and Conti ProContact tire ticked my bathroom scale at 33.6 lbs. This tire in this size is listed on tire rack to weigh 18 lbs. That leaves 15.6 lbs for the steel wheel and plastic hub cap.
The 17x7 inch Porto wheel and 225/45/17 Conti ExtCont DWS ticked the scale at 42.8 lbs. This tire is listed on tire rack to weigh 21 lbs. That leaves 21.8 lbs for the Porto wheel.
Roughly I saved 9.2 lbs per corner or 36.8 lbs all around.
I will keep tracking fuel economy on fuelly.com (sig link) to see if this wheel/tire swap will result in consistent long term fuel savings.
I checked a couple of tire size calculators and they all suggest that the 195/65/15 tire/wheel combo is practically identical in total diameter to the 224/45/17 tire/wheel combo so there will be no odometer and speedometer discrepancy.
Here are the photos for reference:
"Before" (from factory):
20150321_175727
"After" The previous owner of these steel wheels spray painted the hubcaps black. I have no desire to pay $40/piece to replace them with silver ones so it rolls in this fashion:
20150414_160242
