Bob_Fout
Oil Wanker
Given the power/torque graph of the 90HP TDIs where...
Taking gearing, HP and torque into account, will max acceleratlion be had shifting at 3000 RPM, 4000, 4500 RPM, or somewhere in-between?
- Torque peaks and levels early (2000 to 2500 RPM) then starts slowly dropping
- Torque meets the rising HP curve at 2900 RPM
- Torque continues to drop while HP contines to climb where HP peaks and levels off at 3500 to 4000 RPM. Torque is 130 ft-lb to 110 ft-lb in that same RPM range.
