Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old January 13th, 2018, 14:30   #1
Snowman
Unhappy No Heat plus P2457 code
I had low cabin heat for a period of time and suddenly went to no heat condition at the beginning of this week. Next day the P2457 engine code was thrown.
Is there a way to definitively tell if itís the heater core or a stuck open thermostat?
Thanks!
If I end up needing a core, does anyone have a good source for a new one?
2012 Jetta TDI - White Gold
This message sent via BlackBerry Passport
Snowman is offline   Reply With Quote
Old January 13th, 2018, 17:20   #2
Dieseline
Sounds like a clogged heater core (common) and not letting coolant flow through to the egr cooler. While the core isn't relatively difficult to change, I would definitely try back flushing it first. Take the hoses off that go to the heater core. Then flush with a garden hose on one side and then the other. You will see the clog pop out in large pieces and then smaller ones. Keep doing until nothing flows but clear water. It's usually easier to take the hoses off of the engine and use the hoses (still connected to the heater core) to flush it out. Rather than getting to the firewall and just sticking a nozzle into the core at an awkward angle. If for some reason flushing doesn't fix it, 1stvw parts is a great online VW parts supplier. Good luck!
2009 Jetta 2.0 cr tdi - Malone stage 2 with dpf and egr delete, Malone dsg tune, buzzken off-road pipe. Bought back by VW
2015 Jetta SE TDI dsg 50mpg stock for now
Dieseline is online now   Reply With Quote
TSB for clogged heater core / code P2457 inthewoods VW Passat Family (NMS and B7) TDIs (2012+) 70 January 14th, 2018 12:38
Got the fix and now have P2457 N2UADTDI Dieselgate - VW Group Emission Scandal 87 January 3rd, 2018 13:33
No heat in MK4 and a P0102 code midairmark TDI 101 4 December 16th, 2017 09:36
P2457 - EGR cooling performance fdhunter VW MKV-A5 Golf/Jettas 8 May 17th, 2017 12:17
P2457 Code - 2014 Passat TDI TDINJ VW Passat Family (NMS and B7) TDIs (2012+) 2 June 25th, 2015 06:10
Page generated in 0.14479 seconds with 12 queries
[Output: 52.31 Kb. compressed to 48.26 Kb. by saving 4.05 Kb. (7.75%)]
