icrashcars
Hello all...any insight will appreciated.
Car has 110k miles
Events in Order
Slave cylinder failed. Had an indy shop replace with the Valeo SMF kit.
Drove the car for a few days and the clutch pedal became soft again. (no trans noise)
I bled the system, soft pedal remained. (no trans noise)
Replaced the Clutch Master Cylinder - pedal is firm, but now the the trans is very loud when driving (louder than the diesel engine!) At idle, it sounds like the flywheel may be rubbing? (only drove around the block) Shifts fine.
Thoughts?
Pic for attention
Untitled by britt edward, on Flickr
Car has 110k miles
Events in Order
Thoughts?
Pic for attention
