turbocharged798
My dad owns a 1999.5 A4 ALH Jetta with 208K mi on the clock. Normally, we go through a quart of oil per 7K miles. From searching this site, this seems the be the norm. But lately, I think there is a big issue. I just started the car and was backing up when I goosed the throttle and a big puff of blue smoke came out of the exhaust.I had all the windows open, so the smoke came right into the car. I figured it was was because we were due for injector nozzles so I didn't pay too much attention to it until I smelled it. It smelled like pure motor oil burning. While it is idling I can see a blue haze. When I rev it, I can see puffs of blue smoke. I was busy at the time, so I put checking the oil on the to-do list. Just tonight, by dad pulled the dip stick out and there was just a bit at the end of the stick. It must be 2quarts low. We changed the the oil just 5,000 miles ago. It does NOT normally burn this much oil. We don't even have enough oil on hand to fill it the the full mark.
The turbo was replaced at 125,000 mi by us. We never changed the setting on the actuator on the new one when we replaced it. Could it be due to the turbo is overboosting and killing it's self? I checking the boost pressure with the vag-com a while back, and I remember the actual line was a bit higher than the requested line. Also top EGR rubber boost pipe swells when I rev the engine.
Any thoughts?
Any thoughts?
