burpod
teh stallionz!!1
- Joined
- Nov 27, 2004
- Location
- cape cod, ma
- TDI
- 82 rabbit vnt ahu, 98 jetta vnt ahu, 05 parts car, 88 scirocco.. :/
i don't really plan to update this thread at all, but just to demonstrate the power of the dillblox
since i had to fix some wiring in my brothers car i figured it was time to relay the headlights, fogs, and clean up some factory mess. and i had some stuff from my previous wiring ventures that i had never got around to working on.
so i removed the coolant gp box and snipped those wires to put different ends on. i like to run the passenger headlight/etc wires up along the top of the front instead of splitting them and having them run under the window cowling. shaved off the edges of my dillblox and cut a couple edges off with the razor on the factory gp box. perfect fit!
end result is this (not fully done, but you get the picture)
omron relays from mouser.
1 40 amp relay for coolant gp 2/3, 1 40 amp relay for coolant gp 1, 1 40 amp relay for high beams, 3 micro relays (15 amp continuous) for lows, fogs, and lift pump. then fuses for 3 plugs, lift pump, 2 lo, 2 hi, 2 fog
