evguy1
I'm looking for interest in a line of adapters to put TDI's into various vehicles.
We currently build adapters (for 25 years) for installing electric motors into a whole list of vehicles so we have a bunch of patterns.
I'm just starting to install a TDI into my Jeep and bought the adapter from a vendor but the clocking is just not what I want so we started to look at building our own.
We can build a two part adapter so one side bolts to the TDI and the other side bolts to the vehicle trans. There is a spigot that keys the two parts together in whatever position you want to orientate your engine.
This would add about 1.5 - 2" between the engine and trans which helps with vacuum pump clearance to the firewall on most vehicles.
We have patterns for most small trucks and cars as well as some V6 and V8's.
They would be cast aluminum and CNC machined with a steel crank adapter.
Cost should be in the $900 range.
I'll build the first one for the AX15 trans in my Jeep and post some pics but it will be a month or so before we get it built.
Comments?
Randy
Comments?
Randy
