Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old June 19th, 2018, 01:44   #1
xjay1337
Default Performance Common Rail parts (good for 400hp!) / Turbo / Head / Injectors
Right as I am splitting my car the engine etc is for sale.
I am happy to ship parts world-wide although bear in mind shipping will not be cheap as some items are heavy and I will only send insured etc.
I am open to reasonable offers ,
These parts owe me much more than I am selling them for, the R&D on this project was not cheap.
First of all GTB2260 VKLR Hybrid
This is a completely custom turbo built to my specification with no expense spared and is basically brand new having done about 300 milles in total before being removed due to splitting car for parts
Included is a Ported Darkside tubular manifold. No cracks etc.
It is a ROUND PORT manifold so will fit BKD, PPD and CR round port heads
It made 395hp / 665nm at just over 3 bar on my 2.0 CR on a hot day, with fuel pump, larger injectors, ported head and valve springs (the cyl head and injectors are available seperately from myself). Fuel pump can be sourced from Bobby Singh if required.
The turbo is a very special unit originally brand new and built by a European specialist but it had some issues so I had it rebuilt at great expense , and upgraded even further..
It has a massive 52/70cw and custom turbine wheel, with twin seal so no oil leaks
.... Genuine garrett seals and bearings....
Also included is a speed sensor that was custom made using an OEM sensor and converter unit , in my case we had this plugged into EGR valve plug to measure output. I can provide you rough shaft speeds once purchased as well.
Also has EMP port plumbed in for easy access. (Emp is very low on this unit almost 1:1)
Further more it has water cooling as well including an adaptor to use the heater matrix and some coolant lines.. so the option is there if you want to run the watercooling. (I would recommned)
This is basically a brand new turbo and Tubular manifold ready to go in perfect working order
For the turbo and Manifold I am asking £1750/$2300 collected from Calne SN11 in the UK
Obviously if you want shipping then this would be extra
2018-04-19_10-09-12 by Fat Bear Photography, on Flickr
20180615_195258 by Fat Bear Photography, on Flickr
20180615_195322 by Fat Bear Photography, on Flickr
I also have a custom intake for this with larger MAF , PCV pipe and suitable hoses for an extra £120 / $160.
2017-04-16_09-46-10 by Fat Bear Photography, on Flickr
Additionally I have Common Rail CBB/ ROUND PORT ported head for sale
These are fitted with BSR valve springs
I have yet to remove it from the block but will do soon.
20180610_184954 by Fat Bear Photography, on Flickr
I can also include a different inlet manifold for this head that flows better than stock, with runner flap removal (still OEM part so perfect fit)
Have had this for 18 months or so and been perfect with no issues.
Obviously I would strongly recommend getting this checked before fitting and skimming if necessary.
£1000 / $1300 plus postage
Custom injectors - £800 / $1050
These flow much more than stock and retain OEM cold start, part throttle and cruise characteristics.
I will provide you the relevant information for mapping once purchased (IE flow rates etc).
The injector bodies were machined to fit like OEM using OEM seals, without leaking onto the cam cover etc.
In conjunction with CP3 you can get enough fuel for 400hp from these with OEM reliability and smoke.
Any questions please ask.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3” Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old July 9th, 2018, 00:55   #2
xjay1337
Bump open to reasonable offers?
Old July 9th, 2018, 15:52   #3
travis45
travis45's Avatar
PM sent
14 Sportwagen. 267hp last time at the Dyno.
travis45 is offline   Reply With Quote
Old July 13th, 2018, 14:57   #4
xjay1337
Injectors no longer available.
Head and turbo still available.
Old July 23rd, 2018, 06:54   #5
xjay1337
Bump. Injectors sold and shipped to USA.
Turbo and head available still.
Old July 23rd, 2018, 14:51   #6
dieselherb1
How much for head?
dieselherb1 is offline   Reply With Quote
Old July 24th, 2018, 02:08   #7
xjay1337
Copied from the advert.
It's pretty heavy. I ran a quick quote for shipping to USA.
For 30KG item , fully insured is $173.
As I said, open to reasonable offers.
Old July 28th, 2018, 06:40   #8
travis45
travis45's Avatar
Got the injectors. Super fast shipping. Thank you!
Old August 21st, 2018, 11:19   #9
xjay1337
Bump.
Head available
CP3 kit also available now.
Turbo / intake etc also available.
Old August 21st, 2018, 17:34   #10
dieselherb1
Do you still have fluidamp pulley?
Old August 22nd, 2018, 06:27   #11
xjay1337
I have never had a fluidampr mate.
Old August 22nd, 2018, 14:30   #12
dieselherb1
Did you have head studs?
Old August 23rd, 2018, 00:36   #13
xjay1337
No, 12.9 bolts.
Old August 27th, 2018, 06:08   #14
dieselherb1
Is head complete?
Old August 28th, 2018, 00:47   #15
xjay1337
Minus injectors
Minus fuel pump
otherwise yes.
Common Rail injectors TDIA3 TDI Power Enhancements 73 October 31st, 2018 09:40
WTB common-rail injectors for my 09 06dieselpower Private TDI Items for Sale/Wanted 0 January 31st, 2015 04:51
set of 4 common rail injectors brandonfast Private TDI Items for Sale/Wanted 6 December 9th, 2013 13:10
FS: CBEA Common Rail CR 2.0l TDI Engine Parts - Turbo Self Destructed, 125k miles TmpaFL2000Dsl Private TDI Items for Sale/Wanted 7 May 7th, 2013 05:35
Common-rail 2011 performance Diesel_Benz TDI Power Enhancements 3 February 9th, 2011 06:45
Page generated in 0.17496 seconds with 11 queries
[Output: 129.53 Kb. compressed to 108.70 Kb. by saving 20.83 Kb. (16.08%)]
