RuneTDI
- Joined
- Dec 16, 2007
- Location
- Hudson Valley, NY
- TDI
- 2013 Passat TDI SEL Premium, 97 passat tdi (SOLD)
just did brake job- after 200 miles, rr wheel smoking???
?????? replaced all 4 rotors, all the pads, cleaned and lubed everything, replaced fr caliper (piston would not go back in), new rear bearings, races, grease, bled all 4 calipers. everything seemed fine, felt great for first 200 miles. i worked last night and today (car sat in heavy rain all night w/ the ebrake on). i start my drive home at 5pm and start to smell that yummy burning brake smell when i got on the interstate. i figured it was another car or truck, lots of traffic. after a few miles i still smell and say- oh no! i stopped at a friends house and crap- my rr wheel is the culprit. didn't smell too bad , but this couldn't be normal. the car would roll on the slightest grade so i saw that as a good sign, not being locked up. i went on my way and would check again in a few miles. i stopped and checked again and now i have some smoke coming from the pads but can't tell if the brake quiet goo is smoking or the pad to rotor surface is smoking. the ebrake cable was moving at the bottom of the caliper, but i'm still not sure if the caliper or cable is the problem. i waited 30 minutes and then drove the remaing 30 miles home at 45 mph, with no smoke, no burning smell but slightly still warmer than the other side. made it home with no further damage, but did notice early on that the rotor did discolor to a lightish blue.
what do i do now as far as telling what the problem is? it must be the caliper piston getting stuck or the ebrake cable/mechanism holding the pads on the rotor. is their any preventative maintenance on that cable?
are my pads and rotor toasted? can i still use them? get the rotor resurfaced or sand the rotor and pads?
btw, i bought the rotors and pads from tdiparts.com as a front and rear brake kit, 97 passat. and i drive it very gentle, no hard braking accelerating, or cornering.
any help or suggestions would be greatly appreciated. thanks, rune
