jackfolstam
What are the differences between the two ECM's in terms of options and performance (is there a point to go from 80 to 121)? I want to get a tune and am debating whether it's worth it to change over to the 121 pin first because it has to be better, right? Like it's a newer design for a reason, and hopefully that's because it is better?
So far here is what i understand:
80 pin
121 pin
Thoughts:
80 pin
- Immo 1 (no immobilizer), don't have to pay for immo delete when swapping or tuning
- no flashing, have to chip socket, one time additional charge
- metal clip connectors
- spliced sensor grounds
- hot start problem, left foot braking 'problem'
- I think I read that the 80 pin has one fuel map (2D map) or something?
121 pin
- Immobilizer: pre 2003, immo 2, 2003, immo 3.
- Flashing possible over OBDII.
- D shaped connectors (except pre 2003 needle lift sensor)
- one ground per sensor as well as other more minor harness changes
- No hot start problem, no left foot braking 'problem'
- I think I read that the 121 pin has three fuel maps (3D map) or something?
Thoughts:
- Immo: I don't know the differences between the immobilizers but I assume I have to pay to get them deleted, as in I can't diy them out. I have an 80 pin ALH swap in a Mk1 so I just want the delete and don't have to program the ecu or keys at the dealership.
- Chip socketing vs flashing: I read here a few people say they don't think the chip sockets are durable. I want to tune my car in steps, from just injectors, to injectors and turbo. This means multiple changing of the chips, and probably more to come in the future.
- Wire harness: I don't want to swap out the whole harness as it is an engine swapped car, and the harness is kind of cut and spliced into the car in many different places. If I change to 121 pin I'd rather just change the ECM connector or make an adapter at the ECM connector from 80 pin to 121 pin.
- Wire harness differences besides ECM connector: Same as above.
- Hot start problem: I see that Malone can tune this out but does Kerma? I'm interested in Kerma because they will tune multiple times for the price of one tune if you buy parts from them.
- 2D vs 3D fuel maps: Is this true or just theory crafting? Called Kerma and they said no difference, local Malone dealer said no difference. I think this is the main driver to NOT swap to 121 pin.
