Old October 4th, 2016, 20:10   #16
Electrodynamic
Electrodynamic's Avatar
Fuel Economy: 47 mpg
Wow, nice find! Hope you get it running pretty soon. This forum is awesome with help and tips - tdiclub recently helped me find out that the previous owner of my car had the aftermarket catch can plumbed backwards which was the reason it was spitting oil into the air intake.
Current car:
Previous car:
Electrodynamic is offline   Reply With Quote
Old November 18th, 2016, 04:03   #17
GIDDY_UP_GO
Fuel Economy: 39mpg (But I drive 80mph alot!)
Finally got around to taking the Jetta to my TDI guy. Told him I was in no hurry because I am waiting to get my moneys from the 2015 Jetta I am selling back to VW for the TDI buyback.
Hopefully he can get it running for me and this car will replace the one I am selling back to VW!
2004 Jetta TDI 183k mi
2010 Jetta TDI 155k mi (Fix Completed 12/17)
2015 Jetta TDI 40K mi (Did the buyback on 2/17)
2015 Golf SportWagen 4000 mi
THIS WILL MAKE YOU CRY!
GIDDY_UP_GO is offline   Reply With Quote
Old November 18th, 2016, 04:45   #18
hughesjasonk
hughesjasonk's Avatar
Fuel Economy: ?? Drive it like you stole it ??
I'm with everyone else. I would make sure that the thing is timed. if not then look at normal culprits showing a damaged head. if that checks out then start looking at fuel. since it sat for so long I would definitely reprime the fuel system.
hughesjasonk is offline   Reply With Quote
Old November 18th, 2016, 18:45   #19
GIDDY_UP_GO
Just got a call from my mechanic. He hooked it up to VagCom and it had 30 codes. Main culprit seemed to be the cam position sensor. So, that's where we are starting.
Would that keep car from firing? Also, would it somehow also be responsible for the diesel in the oil pan?
Old November 18th, 2016, 19:06   #20
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Cam position sensor could certainly prevent the engine from starting. If there's Diesel in the oil pan (like how much??) - there are fuel galleries in the head with O-rings sealing the injector bodies from the cylinder head. Lift off the valve cover and describe the condition of the cam lobes and lifters under them.
Old November 19th, 2016, 03:37   #21
Keep in mind that when you crank a TDI and it doesn't start it will throw a lot of codes. Some are meaningful, some are symptoms of the cranking. I trust your mechanic knows enough to discriminate between codes.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old November 23rd, 2016, 13:50   #22
GIDDY_UP_GO
Took it to my TDI guy and he put a new cam position sensor on it and found out that when the previous owner installed a new injector in #3 cylinder he either stripped out the hold down bolt or the bolt came out on its own. (I will know more Monday when I go down and look at it myself)
Anyway, here is my question: Should I have him try to run a thread chaser down the hole and get a new hold down bolt? Or should I get an insert and go that route?
I really don't want to purchase a new head. Could I JB weld a threaded rod in the hold down hole and use a lock nut or double nut the injector hold down? I am just throwing ideas out there.
If anyone has any good ideas, or past experience, please throw em out there!
By the way, the previous owner had a non-tdi mechanic replace the #3 injector not long before the car quit running. I am assuming that he over-torqued the bolt or didn't use a new hold down bolt (I believe these are stretch bolts and one time use only if I remember correctly)
My 1982 diesel rabbit pickup (Barn Find) phucking-low Other TDI/Diesel Picture Gallery 71 October 5th, 2013 05:58
Portuguese Barn Find TomJD General Automotive 3 February 3rd, 2012 08:04
CL Barn find? 05' Passat with 28K miles (not mine) Namakan TDI Cars for Sale/Wanted 0 August 25th, 2011 19:15
Where can I find a RED rear foglight bulb for an '04 Jetta? MEIN_VW Ontario 5 May 26th, 2010 10:05
Barn find of all time! Sooch General Automotive 19 January 13th, 2009 12:18
Page generated in 0.13281 seconds with 11 queries
[Output: 84.28 Kb. compressed to 73.48 Kb. by saving 10.80 Kb. (12.81%)]
