Old April 5th, 2014, 17:23   #46
trailhead
trailhead's Avatar
I have a 1000w Frostheater up front. Instead of running the plug through the grill, I have it plugged into an extension cord that runs to the marine charger plug in my rear bumper.
2005 Jetta Wagon, VNT-17 5spd, Short Shifter, Stage 2 w/D Idle, Muffler delete,
GLI Brakes, GTI interior, 2" Receiver, Frost Heatr, 4 note Cadillac horns, LED's, Skid plate.
My car; http://forums.tdiclub.com/showthread.php?t=387234
trailhead is offline   Reply With Quote
Old April 13th, 2014, 20:14   #47
trailhead
trailhead's Avatar
Today installed a vented right inner fender;
Replaced the bolts on my wheel spacers;
Installed a set of pimp wheel nutz;
Old April 16th, 2014, 20:14   #48
thebarber
i like your nuts
thebarber is offline   Reply With Quote
Old April 17th, 2014, 19:45   #49
trailhead
trailhead's Avatar
Hahaha. Best post I read today! Thanks
Old April 21st, 2014, 18:34   #50
trailhead
trailhead's Avatar
Today I replaced 3 o-rings and a clip on my boost piping and did a little diy mod to the top clip-a-ma-thingy.
Old April 24th, 2014, 20:17   #51
trailhead
trailhead's Avatar
I'm so stoked! The o-rings and extra clamps, etc have fixed the annoying hesitation I've had since I bought this car! Near as I can tell; the pressure side would burp as the turbo came on, causing a single "pop" type hesitation. It's like a new car! Yay! now I can tune it!
Old June 2nd, 2014, 11:55   #52
akrievins
akrievins's Avatar
Good work so far! I like those tire chains! How have they worked? Where did you get them? I really could use those up north in the winter, even with snow tires.
akrievins is offline   Reply With Quote
Old June 2nd, 2014, 13:02   #53
trailhead
trailhead's Avatar
The chains are great. I run snows but, they're no match for my cottage driveway. They have a top speed of 20-25km/hr so they're more of an emergency device than a everyday use item. Kneeling in the snow and reaching to the back of your snow filled wheel wells to install them is not a great time but, as a saved-my-ass tool I give them a 10/10. Last winter they got me up my 300' 5-6% grade driveway after my snows refused to do the job.
I purchased them at Princess Auto for $60 on sale, regular $99 ( iirc )
The auto adjuster devises are plastic. They worked through the 5 (or so) times I used them last winter but, I'm not sure I trust them to last forever. This winter I'll carry 2 back up turnbuckles in case a tensioner breaks.
Old June 5th, 2014, 08:33   #54
akrievins
akrievins's Avatar
This is great news. I too have a very steep section on the cottage drive way... Had a RWD Infiniti G25 last winter and I got stuck big time in some wet snow. Needed a tractor to pull me up after messing around for an hour. I even had snows and a pile of weight in the back. Great report on the chains. Any specific info you can provide? Make, model? Were there different sizes? I just want them for my 15" or 16" wheels on the golf when I decide what winter tires and rims I'll be using.
Old June 6th, 2014, 03:43   #55
trailhead
trailhead's Avatar
Here ya go; http://www.scc-chain.com/tire-chain-...tirechains/167
Old June 6th, 2014, 10:59   #56
akrievins
akrievins's Avatar
Thank you sir!
Where is your cottage located? Our family cottage is just south of Parry Sound right near Lake Rosseau.
I head up the 400 quite a bit, so if your cottage is in the Muskokas I might see you battling cottage bound traffic someday.
Old June 6th, 2014, 14:06   #57
trailhead
trailhead's Avatar
I'm in Prince Edward County. No 400 to deal with but, the Montreal bound 401 drivers are every bit as nutty! I do go to Blue mountian a couple time each summer to ride but, I avoid times when the cottage crazies are mauling each other's bumpers.
Happy trails, let me know how the chains work next winter.
Old November 18th, 2014, 11:20   #58
MateoCicoria
MateoCicoria's Avatar
Fuel Economy: Avg'd 46 Before Winter
Do you have a thread dedicated to that boost 'burp' you cured?
MateoCicoria is offline   Reply With Quote
Old November 19th, 2014, 06:07   #59
trailhead
trailhead's Avatar
Sadly the hesitation returned .
It's so weird, how intermittent it is. I inspected my cam again yesterday. It's very hard to get a good look at the lobe profiles but, I think I see some wear. I'm gonna take it to a guru for a second opinion..
Old December 1st, 2014, 20:59   #60
cbalthazor
So, when you did the steering wheel swap did you have to add the controller and clockspring and whatnot to get everything to work, or was it plug and play since the 04/05 cars since the Leather wheel as an option?
I've been debating doing this for a bit (2004 PD), and could only find writeups on converting ALH cars to the steering wheel.
cbalthazor is offline   Reply With Quote
FS: 2004, Jetta, Wagon, BEW/PD, 5 SPD (Connecticut) ctnatureboy TDI Cars for Sale/Wanted 23 August 22nd, 2012 11:38
Can 5spd PD Jetta get 50+mpg like 5spd alh? vdubber4life TDI Power Enhancements 12 May 20th, 2012 11:53
WTB: 2004 Jetta Wagon PD TDI w/ 5spd, or 2001-2003 TDI wagon barooo TDI Cars for Sale/Wanted 11 January 14th, 2010 20:33
04 Jetta Wagon TDI PD BEW Waste Actuator JCFINKEL TDI 101 12 July 2nd, 2009 08:38
Page generated in 0.19713 seconds with 11 queries
[Output: 132.68 Kb. compressed to 110.84 Kb. by saving 21.84 Kb. (16.46%)]
