ak47tdi
A little backstory.
I finally got my motor together and my 99 Mk4 Golf running again this fall. It was down for just short of two years after I cracked my #2 piston in half. I had my fair share of obstacles and hold ups. It took some time to gather all the right parts and put it back together the way I wanted. It was well worth the wait in my opinion and I'm really happy with the end result.
My motor now consists of the following.
Dblias 260 camshaft
Rosten dual valve springs
Rosten Titanium retainers
Stg4 ported, polished, and rebuilt head by Passenger Performance
Bosio RACE 520 nozzles
ARP head stud kit
80mm oversized ASV pistons
18.5-1 compression pistons via reshaped combustion bowls by Shortysclimbin
Swaintech coated piston tops
Integrated rifle drilled H-beam rods
Calico treated rod bearings
ARP rod bolts
Eurospec main girdle
ARP main bolts
Eurospec full steel oil pan
Fluidampr crank dampner
Eurojet 3" turboback exhaust
Southbend Stg5 hybrid clutch
Vibrant CCV scavenging kit routed into downpipe
Now that the motor is up to the task it is time to say goodbye to the 17/22 and move on to something bigger. The Darkside kits caught my eye because I'll be able to use all my existing intake and intercooler piping. I like the way my engine bay looks now and i want to change as little as possible. My kit showed up last week and I couldn't be happier with the way everything looks. Amazingly beautiful build quality and materials. For now I just have pictures of the kit, but I'll be updating this thread as I go forward with the install. I'm disassembling the turbo this week/weekend to send the exhaust side and manifold out for coating. I'm excited to get this kit on and drive the car, should be fun
Pre existing mods.
Stg5 software by Rocketchip
Euro PD130 Passat intake manifold
Custom FMIC and powdercoated piping
CAT 2 fuel filter w/ Kerma widget
11mm injection pump
PD in tank lift pump
PD130 Passat oil cooler
Rebuild and powdercoated 02J
G60 stock weight flywheel
Peloquin differential
108mm (1.8T/VR6) output flanges
Driveshaft shop stg2.9 axles
B&M and Gruven parts short shift kits
H20 2009 was the last show before the motor bit the dust.
Two weeks later...
So she got torn down.
(That's my trusty 2 liter beater behind the TDI.)
Dblias 260 camshaft
ARP head stud kit
ARP rod bolts
ARP main bolts
Pre existing mods.
11mm injection pump
Two weeks later...
