Old February 16th, 2016, 18:11   #16
goodmonkey
goodmonkey's Avatar
When installing the MFD control stalk I also swapped out the steering wheel for the GTI one.
While I really liked the feel of it, I didn't realize just how much smaller the diameter of the wheel was. It impaired my view of the instrument cluster. The most likely could have been rectified by changing the way I sit, but I refuse to, so it came out. I'll have to put it up for sale soon.
When my new SWCM came in, I had the final piece to my puzzle. To get the MFSW to work, I had to merge these two cables, as I couldn't find the correct one for the two stage airbag setup.
While that worked, I did run into some other problems. It turns out the SWCM ending in CH does not support dual stage airbags. It really is as simple though as two pins are missing where the clockspring plugs in. I'm not going to try tackling that, instead I have a AJ version coming in sometime soon. So now I'm riding around with an airbag fault. What really irritated me though was the turn signal/cruise control stalk I bought was faulty. It would only signal left turns and the cruise control switch was reported faulty by VCDS. So tonight I took it all back apart, again, and put back in my dual stalk, which seems to work. And for anyone who wonders how to get that T8 screw out (I have NO kits with a T8), I just used the 2mm flat head screw driver that was part of my jeweler's kit. Worked fine for taking it out and putting it back in, though I would prefer a T8 so not to bugger it up anymore.
This is how it looks now. I miss the feel of the GTI steering wheel, but this one the view is so much better. I also appreciate having the bigger steering wheel because my power steering requires a reset that I've not been able to get out and do (but have driven the car 100 miles today). I'm trying out the vent GPS mount. For $7, I figured why not.
2014 Passat TDI SEL (DSG) - 71k, 2007 Silverado Duramax - 422k
Previous TDI's: 1996 Passat TDI- totaled at 394k miles, 1998 Passat TDI - 175k miles, 2012 Passat TDI SE - 41k, 1996 Passat TDI Variant - 327k, 2014 Jetta SportWagon TDI 6MT - 29k, 2015 Passat TDI SEL - 18k, 2006 Jetta TDI 5MT - 261k
goodmonkey is offline   Reply With Quote
Old September 25th, 2016, 09:39   #17
goodmonkey
goodmonkey's Avatar
I've not made any real progress on the car, it has been a crazy year. So I keep driving it. I hope that things are changing soon and I can get some things done, like dropping the headliner to fix those lines finally.
I took her out on a 250 mile trip to pick this up though. It is my replacement for the Sportwagon.
Old October 6th, 2016, 13:21   #18
relumalutan
relumalutan's Avatar
Can you please post the steps you took to install the radio?
relumalutan is offline   Reply With Quote
Old October 26th, 2016, 16:27   #19
goodmonkey
goodmonkey's Avatar
You can follow pretty much any how to out there on pulling out a MkV radio. The trick with the RNS-210 is the CAN-BUS connections. I've found this video which talks you through it. I bought my whole kit, wiring adapter and all, from AliExpress.
https://www.youtube.com/watch?v=NvCwxehmoIA
Old November 2nd, 2016, 13:50   #20
goodmonkey
goodmonkey's Avatar
Got some new goodies today! New under hood insulator, Volks-L, left and right fog lights, and part of the drivers knee cubby. I bought this trying to use up our Goodwill package card before it expires this month.
[A picture should be here]
The under hood insulator is probably the only thing that will get installed soon. I still have to buy the grill pieces and wiring for the fog lights, another part to install the cubby, and if I install the Volks-L then I have to take my RCN-210 out and put the Premium 7 back in. I'll figure it out eventually though.
Old February 18th, 2017, 18:46   #21
goodmonkey
goodmonkey's Avatar
Default Rns-315
After working nearly 9 hours on the sunroof drains over the past two days, I installed this RNS-315.
Hopefully I used enough silicone this time to keep the water out of the passenger compartment. For the rear drains it is all where the hoses connect to the rails, and I got to see what happens when you overload the drain rail (it goes over to the rail with the sunroof and drops onto the headliner).
I was surprised I could snag an used RNS-315 version D for $200. It has been a while since I've looked at them I guess. Maps is version 3, and I know they have released version 9. According to the outfit I bought it from, it was pulled from a 2013 Passat. I'm waiting for a mic and harness to come in to be able to use the Bluetooth Handsfree. Radio sounds pretty good. Will see in the morning if I need to replace my Gateway controller. I didn't realize when I bought one it was from a Bettle, and it didn't play very nicely with my car when I installed it. Went back to my original for now.
Old February 27th, 2017, 14:44   #22
goodmonkey
goodmonkey's Avatar
Default Fog Lights!
Got around to doing some work to the car this weekend. First up was to install these OEM projector fog lights. They are wired into the CECM and work like they should. With this CECM I was also able to set them up as cornering lights. Haven't done any driving after dark to see how well they work, but they defiantly have a good cutoff.
I also got around to finally adjusting the timing. I meant to do it shortly after replacing the timing belt about 10k miles ago, but left the Torsion value at -2.9. It was at -3.4 before I adjusted it. It was getting a little harder to start and producing more black smoke. That combined with only 39 MPG average got me to take care of it. Torsion value is now at 0.0, which was surprising to get that with the first adjustment. It starts a little faster now and produces less smoke, and power seems more linear vs a big boost around 1900 RPM.
Old November 12th, 2017, 16:44   #23
goodmonkey
goodmonkey's Avatar
Default Depo Projectors
Trying these things out. So far, not too bad. More to follow.
Old November 25th, 2017, 15:36   #24
goodmonkey
goodmonkey's Avatar
Default Light cut off and next project
NOTE: Pictures are on Google, and have disappeared before. If they do again, send me a PM and I'll try to fix.
As promised, here is more about the new lights. They are HELIX E-codes, with leveling motors. Now I have none of the controls for the auto leveling, and don't know that I will. I just swapped the H7 bulbs from the OEM lights into these. I'm debating trying some LED H7 bulbs just to try them out. I think I like the OEM light better, mainly because they aren't projectors. These don't allow enough scatter to the right so signs are lit up, and the cut off with the halogens look like it doesn't go as far. I've not actually tested against the OEMs though. I did see that on a fairly level run on the Interstate I was able to light up a reflector 10 seconds in front of me at 70 MPH, and that is just over 1000 feet. That isn't bad, but I don't know that I checked that same thing with the OEMs.
Here you can see the cut off against my garage door. Here I have the right adjusted just a little high, so the light steps up twice from left. I was trying this to see how it looked while driving.
Out on the road, it looks a little like this. On the right you see a street light, not a sign reflection.
Lastly, here is a picture of what is to be my next big project with the car. I'm going from single zone semi-automatic Climatic to dual zone full-automatic Climatronic, or at least I'm going to try.
Last edited by goodmonkey; December 5th, 2017 at 09:50. Reason: Photos disappeared - now these are on TDIClub
Old December 5th, 2017, 10:05   #25
goodmonkey
goodmonkey's Avatar
Default RCD-330 Plus Installed
Last night I took an hour or so to install a RCD-330 Plus (version A) that I bought off ebay. Things I like: responsiveness, great reception (at least sitting in the driveway), getting back the delay of shutting down until I remove the key from the ignition (with other radios they turned off when I turned the ignition off), auto turning screen off, and quick connection BT. I don't think I'll miss the lack of a CD drive, but I will miss built in GPS functionality. Now I have to decide if I need to buy a dash top GPS unit or just use my phone.
Old December 12th, 2017, 19:23   #26
relumalutan
Please keep us posted in regard to the climatronic swap.
Old January 1st, 2018, 10:30   #27
goodmonkey
goodmonkey's Avatar
Default Climatronic Swap
Initially when looking for a MkV Jetta I was looking for one with all the bells and whistles. The price that those cars commanded was more than I really wanted to pay, plus I was out of town most of the time I was looking. Adding to that the fact that there really aren't that many TDIs in my market for sale (that I've ever been able to find) I drove a few hours away to pick this one up. I've been happy tinkering with it since then, adding things here and there to get me where I wanted to be initially. After undertaking this modification though my wife wonders (as do I sometimes) why I didn't just pay the extra money initially.
A swap of this sort seemed too large an undertaking, until I saw posts from 2008 where maloosheck had done it to his, and I thought this could be something I could do. His rundown of the basic steps to complete it made it seem as easy as removal and replacement. I took the plunge rather quickly and after only searching a couple of nights bought a donor air box for the swap. After studying schematics, pin outs, as well various removal instructions, I decided to dive in. How long could this take anyway? Maloosheck said he could have done it in 3 days if he hadn't socialized.
For those who may be looking at this wondering what I'm doing, I'm swapping my Climatic, single zone, semi-automatic heater and A/C system for a Climatronic, dual zone, automatic heater and A/C system. Here is what I'm starting off with:
Most of the work around the center vent and steering wheel I've worked with removing before, but hadn't removed the center console, passenger airbag, or dashboard before. After only three hours in and progress like this, I'm thinking I'm doing pretty good.
It was somewhere in here that I noticed my drop light started to flicker, and noticed that the CFL housing had come apart. The light did drop earlier that day onto the garage floor. Maybe that did it in.
Progress slowed down at this point, as I moved to the engine compartment. I thought the heater hoses were hard to remove, but the A/C lines proved to be even more of a pain. The bolts holding the lines to the expansion valve were in there pretty good, and using my breaker bar there wasn't much room to move it, or to even get it in there. I had to stop and drive to Harbor Freight to pick up a longer 3/8" drive ratchet. Upon returning I was able to get the top line loose, but I broke the head off the blot on the lower line. I decided this was a good place to stop for the night, 8 hours or so after starting.
The next day started with a trip to Lowe's to try finding a suitable replacement bolt for the A/C lines. There I found a stainless steel bolt that looked like it would work great, so I went back and got to work on the inside of the car. After struggling to get the final air box bolt out, I stopped and looked at my donor air box. Now I had looked at it briefly before, and now saw what could be a show stopper, a damaged housing!
Getting the two air boxes side by side I started to take them apart to see what really made them different. The main difference is in the air distribution housing, fan assembly, and wiring harness. Further disassembled the assemblies until everything was out, and took the time to wipe mine down on the inside. My heater core looked better than the one from the donor, but my evaporator core was pretty dirty. I took the one from the donor air box, and started to put it all back together.
Finally, I have an air box that should work! The big difference (though unable to see it in this picture) is the series resistor unit that sits unused in my frankenairbox. At this point I still need to run the wiring from the auxiliary heater to the correct place in the wiring harness.
Wiring from the auxiliary heater to the air box wasn't that hard to do. Just twisted together some line (20 AWG, I couldn't get 21 AWG in time) and connect it to the heating unit, and the other end to the connector for the fan. I decided on red and green in part because it was two days before Christmas.
The expansion valve became the hardest part of this whole swap. My intention was to replace it with a new one, as I didn't at the time the compressor was changed in 2016. Unfortunately I was unable to get the line loose from the valve with force, PB Blaster, and the combination of the two. I started to drill out the bolt from behind, where I could better access it in the passenger compartment. After slow progress I stopped, and contemplated the likelihood of it breaking loose going down the road. Considering all I did to it and it didn't, I figured the odds were in my favor. I quit for the night and proceeded the next day.
Day 2 complete. To be continued...
Last edited by goodmonkey; January 1st, 2018 at 10:36. Reason: Finding where photos are at.
Old January 1st, 2018, 10:39   #28
goodmonkey
goodmonkey's Avatar
Default Climatronic Swap, part 2 (because I had too many pictures)
Day 3 I manage to get the frankenairbox in without as much hassle as getting the original out. I then had to build a couple more wiring harnesses for the additional sensors. After repining the main connector for the ventilation controls, I decided somewhere around this point to hook the battery up and test out the servos. At first nothing worked, but it didn't take long to figure out that I needed another power source for just one more pin. With that it seemed all the servos were working, nothing was binding, and I was good to continue putting it back together. I also pulled a vacuum on the A/C system and 45 minutes after I shut the pump off it seemed to be holding around -20 PSI. This is about where I stopped and took Christmas Day off from the project.
Originally I hoped this would only take 2 days by itself for the swap, so I could do some additional things while the dash was out. Unfortunately time didn't work in my favor, so the only thing I did was swap the CCM, and look at repairing the driver's side heated seat. A few weeks ago I pulled the harness connector off a donor car at the local wrecking yard, and hoped to pull the pins to do a proper repair.
Unfortunately at this time my pin extracting skills with a small screwdriver and paperclip were foiled, and I resorted to a different tactic. After 20 years of working on VW's I think I may break down and buy some proper pin extractors. Until then this is my fix action.
Finally, near the end of the 5th day, I got it all back in!
I had to back it out of the garage at this point, and we took off for a small trip to go see my family. I've not been able to charge the A/C because it is too cold for the system to operate once we got back. It looks like the car may be sitting for another week until (hopefully) things warm up enough to charge the system. I also need to get out there and clear the codes from hooking the battery up with lots of things not hooked up. Along with an airbag fault and traction control light, I also have this. I did have some sensors disconnected in the engine compartment when I did that, but have them all hooked up now, I think. It was dark then, the car moved, and now it is cold.
Hope you enjoy the pics!
Last edited by goodmonkey; January 4th, 2018 at 11:32. Reason: I swapped CCMs, not CECMs this time.
Old January 4th, 2018, 11:32   #29
goodmonkey
goodmonkey's Avatar
Default Non-picture update
No picture here, just wanted to say I braved the cold (for SC) and cleared the codes. I was also able to program all the remotes to the new CCM. Of note though, my horn for the alarm is no longer working. I have the coding turned off for the siren (as it was on initially) and still nothing when locking the doors or setting off the alarm. So for now it is lights only until I get this one figured out.
I'm also pleased to report my heated seat works. This is the first time I've felt it in this car. I've gotten quite used to using them in my truck this week.
Old May 23rd, 2018, 18:29   #30
goodmonkey
goodmonkey's Avatar
A/C performance is just as good if not a hair better than before I did the Climatronic swap. Thinking of selling her though and going for a 2015 Passat. I've missed the size of the Passat over the Jetta.
2010 Jetta CJAA 6Spd Transmission compatibility 2006 Jetta TDi BRM Bambaataa VW MKV-A5 Golf/Jettas 1 March 17th, 2013 19:22
3 year comparison, 2006 TDI Jetta -vs- 2006 Prius Rod Bearing TDI Fuel Economy 32 January 26th, 2013 18:51
for trade: 2004 jetta wagon 5spd for 2005.5-2006 jetta GotEuroCorrado TDI Cars for Sale/Wanted 0 September 9th, 2012 15:44
Purchase 2006 Jetta or wait for 2008 Jetta? 58henjef VW MKV-A5 Golf/Jettas 19 July 23rd, 2007 05:49
Jetta TDI 2006 VS Civic hybride 2006 SimonVolks Quebec 34 November 15th, 2005 08:54
Page generated in 0.19250 seconds with 13 queries
[Output: 153.22 Kb. compressed to 129.45 Kb. by saving 23.77 Kb. (15.52%)]
