Old September 30th, 2011, 07:19   #46
johnboy00
At $4k it's a steal but it will cost you more to make it last.
Plan on spending about $3000 to rep[lace the BSM module and VWs other typical screw-ups with this vehicle. If it has transmission problems (not over common but far from rare) another $4k could be needed. If it only neede a torque converter than you could get away with $1200 or so. But even if you had to put all that money into it, it's a pretty good deal.
John
2005 Passat Wagon
2004 Jetta Auto
2003 IBW
1999.9 Golf (for parts)
johnboy00 is online now   Reply With Quote
Old October 1st, 2011, 21:14   #47
CoasterMoose
CoasterMoose's Avatar
Default Love my B5 TDI Wagon.... fuel mileage anyone??
Hi all, great forum!
I recently purchased an 05 Passat TDI Wagon, and was wondering what fuel mileage other B5 Wagon owners are getting.
My first tank of B20 fuel was 36mpg, but my last several tanks of D2 have been around 30mpg. I'm looking into whether the D2 I have been buying has too low of a cetane rating, and if I need additives.
Any feedback and advice will be appreciated. I love this car!
Moose
____________________
Former Owner of a wonderful 2005 Passat TDI Wagon - Unchained on Leap Day 2012
CoasterMoose is offline   Reply With Quote
Old October 2nd, 2011, 08:41   #48
abctdi
abctdi's Avatar
I thought b20 would be lower mpg than d2...
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old January 16th, 2012, 14:56   #49
delaware_doug
Default Chain Broke, now what?
I have a '05 B5.5 w/ 142K & I believe the BSM chain broke this morning (I know, I know) what would likely be damaged besides the BSM/chain/sprokets/oil pump? I shut it off ASAP, but is it worth fixing? (I've owned it since 48K, oil/filter every 5K, all servces done, timing belt/tensioner/water pump/flush @ 105K, I just did TC replacement @ 138K & full F&R brakes/pads/rotors/fluid flush, CV boot for $3,150 in Oct. '11 Looking for advice - do I fix w/ gear driven BSM or do a whole reman engine assy? It's staring to be a "money pit"...
delaware_doug is offline   Reply With Quote
Old February 14th, 2012, 04:31   #50
Julian
Default Power loss
Help required & apologies if i missed the subject in the FAQ list, I have a 2003 b5 Passat tdi 130, on a couple of occasions recently the car appears to have gone into what i can only describe as limp mode, it runs but is very low on power, if i stop & turn off the engine then re-start it again it returns to normal, I have checked all the obvious like vacuum pipes off etc, I know of a couple of other people that have the same problem as myself so presume it is not unique to me but more of a common problem, Can anyone shed any light on my situation please,
Cheers Julian.
Julian is offline   Reply With Quote
Old February 14th, 2012, 05:13   #51
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Find someone with VCDS and have them scan your car. If it is going into "limp mode", there will be a fault code even if the CEL does not come on. It is, most likely, either a leak in the charge air piping, or the vacuum system.
-George Bernard Shaw
Old November 8th, 2014, 15:00   #52
edzha90
TDI(s): 1.9
Does anyone know how to check if the battery is good for winter? I will move soon to country where is cold winters with proper snow etc.
I have two batteries now one in the car and one in my another car, how I can check at home which of two batteries would be the best condition?
edzha90 is offline   Reply With Quote
Old November 11th, 2014, 07:33   #53
abctdi
abctdi's Avatar
Get them load tested at your local parts store.
Old September 7th, 2015, 20:12   #54
sarad
hi, im new to VWs and TDIs, I just got an 05' Passat wagon with about 124K and was wondering what are some things I might want to look out for as the miles go on.
sarad is offline   Reply With Quote
Old September 21st, 2015, 15:32   #55
brandoniehoff
Hi new here. Have a 2005 passat tdi BHW engine. Before and after a fuel filter change the engine will crank, but sometimes not start. It seems to help if you hold the throttle down. Doesn't seem to be any time or temp maybe it does it more after warmed up.
I apologize if I put this in the wrong place.
Thanks!
brandoniehoff is offline   Reply With Quote
Old September 24th, 2015, 04:06   #56
hughc
Thanks!
Both times that I've replaced the fuel filter I've toggled the ignition switch 12 to 15 times before starting the engine, in an attempt to properly prime the fuel system.
In both cases the engine started up immediately and ran flawlessly.
Definitely worth a try.
hughc is offline   Reply With Quote
Old September 24th, 2015, 08:10   #57
abctdi
abctdi's Avatar
And fill the new filter with fuel before starting...
Old December 17th, 2015, 14:12   #58
Syncro92
Default Pd 130 bhw
is it an 8 or 16v engine? Does anyone have a "blow up, see through" picture? Tks
Syncro92 is offline   Reply With Quote
Old December 19th, 2015, 18:26   #59
wtribeflyer
Fuel Economy: Yes
Its an 8v. Lots of info on the interweb. BHW 2.0 tdi
wtribeflyer is offline   Reply With Quote
Old March 17th, 2016, 18:19   #60
SaxmanKana
Originally Posted by scottie_boy99 View Post
i am looking at buying a passat tdi, anywhere from 2003 to 2005, any recommendations as to what year i should get and why? i will be possibly "chipping" it and putting a 2.5" or 3.0" straight pipe exhaust on it... is there any pollution controls on the exhaust? what are these engines rated at stock for hp and torque?..
i am also leaning towards an automatic tranny.... is that a good idea?
thanks for the advice in advance
scott
former 04 jetta owner
I have been checking out a few on my local CL. 03-05 all PD engines? Any year better?
Thanks, Dave
Dweisel's Diesel. Thanks for reaching out to me & selling one of the herd!🐞
SaxmanKana is offline   Reply With Quote
Page generated in 0.16738 seconds with 10 queries
[Output: 121.48 Kb. compressed to 100.78 Kb. by saving 20.69 Kb. (17.03%)]
