Old February 22nd, 2019, 01:27   #1
kaneelschep
Default Good Automatic box?
I read some on the subject allready and I think most people confirm this, but just to be sure.
The automatic in the b5.5 passat is the ok one, no?
So the one with the 432 gear option under the d.
These are all the same? In v6, 1.8t, tdi?
Any tips what to look out for when buying a 2000 passat tdi with this box?
Thanks!
kaneelschep is offline   Reply With Quote
Old February 22nd, 2019, 06:33   #2
PickleRick
PickleRick's Avatar
The v6 and 1.8t automatic are going to have different shift points and torque converter than the tdi. They are all "sport shift" automatics. Yes they wil bolt to the tdi motor but the v6 will be the only one that is even remotely close. I don't think it would run well with the tdi tcu. Even then it would probably not work well. I have the v6 5 speed manual in my passat since we didnt get the tdi 5 speed b5 or b5.5 cars in the us. It works fine unit about 75mph. After that it revs too high.
The biggest thing to look for on a used tdi b5.5 or b5 transmission is service history. These do not hold up well to neglect.
2nd is miles, sub 15000 is good sub 100,000. Is great.
I believe there is an upgraded torque converter and pump that can be installed before tossing it in the vehicle if you want her to be as bullet proof as possible. Oilhammer has abused his slush boxes for years and knows them well. Maybe he will chime in on how he'd prep a used slush box swap. Id go with manual myself if you're ok with a 3rd pedal.
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is online now   Reply With Quote
Old February 25th, 2019, 00:21   #3
kaneelschep
I am sorry. You misunderstood. I dont want to swap anything.
I am looking to get a passat 5.5 tdi automatic. With the 1.9 ATJ engine.
And was wondering if this is the automatic box which lasts.
Since there were some VW automatics from that era that sucked. and I got confused which one.
Old February 25th, 2019, 02:59   #4
PickleRick
PickleRick's Avatar
Assuming its the same zf box we got here in the states its a fine gear box if it was serviced at regular intervals.
High mileage plus neglect on service usually means a limited life expectancy.
Old February 25th, 2019, 05:46   #5
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Some early B5s got a 4sp automatic, do not know which diesel engine it would have been bolted to. We never got those here.
Starting around 2000, ZF made some internal improvements to the valve body of the 5HP19FL transmissions that addressed some issues they had.
Servicing them properly certainly helps, but it is an automatic, and there is zero chance I would ever consider one if I had access to a factory equipped manual box like Europe did. We ONLY got the automatic, and ONLY 2004-2005 as that is the only years any B5 Passat diesels were available here, and those are PD136 2.0L engines.
oilhammer
www.cardocautomotive.com
Old February 25th, 2019, 14:58   #6
PickleRick
PickleRick's Avatar
Liar...you love your slush box.
Automatic Starter and tuning box for sale davidm2232 Private TDI Items for Sale/Wanted 0 September 21st, 2011 09:01
tuning box for automatic afrika_bambaataa TDI Power Enhancements 1 April 4th, 2007 08:35
Automatic TDI chip/box recommendations? sipndsl TDI Power Enhancements 8 September 30th, 2002 06:26
Is Absolute + Tune Box too much for Automatic's? Marissa TDI Power Enhancements 6 March 30th, 2001 06:51
upsoluted automatic tdi with tuning box hotrodtdi TDI Power Enhancements 0 October 28th, 2000 18:22
Page generated in 0.09740 seconds with 11 queries
[Output: 75.28 Kb. compressed to 65.93 Kb. by saving 9.35 Kb. (12.42%)]
