chz17
Is auto transmission and manual one injection pump pulley are same?
You don't remove the IP sprocket off during the timing belt installation. You would have the pump pinned while installing the belt with the 3 bolts loose enough to allow some movement while you manage the belt and then tension.OK. Thank you . I mistakenly used pulley bolts hole to the injection timing hole. Finally figured out. The some holes on the pulley are not same distant to the outline pulley.
