Old February 17th, 2019, 16:01   #1
thompsoncustom
TDI(s): bora
Default Hard starting alh
Rebuilt my turbo and changing out the timing belt, glow plugs, motor mounts and so on.
Now my cars doesnt want to start worth a crap. Checked timing when I got done and it was within range but in the bottom side of the graph so I moved it up to the top side but still not any better.
IQ at idle is between 7 and 8 I have pp764 injectors so I was thinking moving it there might help instead of 4, tho it might have helped a little it's hard to tell if it did anything.
Car always started great before even at -10 if you cycled the plugs twice it started good. Now at 30 above it turns over quite a bit before finally starting.
Any advice?
thompsoncustom is offline   Reply With Quote
Old February 17th, 2019, 17:26   #2
WildChild80
WildChild80's Avatar
My 01 TDI was hard to start, sometimes seemed like it was trying to run backwards... pretty sure it was cam timing, had a bogus cam lock tool. When you had everything at zero, did it start or did you have to move your IP to get it started after the timing belt change?
The graph shows you IP timing, not cam timing, only was to check that is set the crank at TDC and put your cam lock tool in
Sent from my Pixel XL using Tapatalk
WildChild80 is offline   Reply With Quote
Old February 17th, 2019, 19:22   #3
[486]
TDI(s): 02 golf ALH
another vote for cam timing, when mine was retarded to just before where the valves should hit (11 flywheel teeth, iirc) it took a lot of torching the intake manifold to get it to even start
[486] is offline   Reply With Quote
Old February 17th, 2019, 19:55   #4
thompsoncustom
TDI(s): bora
Very well could be cam timing when I got done doing the timing it was dumping fuel into the exhaust i believe maybe from the exhaust valve being open. It would start but I did adjust the iq right away to make up for the fuel.
I dont think anything moved at all but if the cam wheel takes as little adjustment as the IP than a mm goes a long ways.
Old February 17th, 2019, 21:51   #5
WildChild80
Did you use a cam lock and did you knock the cam sprocket off during the timing belt job?
Old February 17th, 2019, 22:23   #6
thompsoncustom
TDI(s): bora
No I did not use a lock tool on the cam. No the sprocket did not come off or even appear to move, painted cam sprocket tho.
Old February 17th, 2019, 22:38   #7
Nero Morg
You can't do that with these engines. The way the timing belt is designed, as you set the tension, the injection pump sprocket and cam sprocket are supposed to rotate as the belt moves to the tensioned position. Then, you are supposed to torque the cam and fuel pump sprocket. Doing it the way you did, will end up in the cam or injection pump being off.
2003 Jetta Wagon silver- DLC520 VNT15 11MM pump 5 speed
ESP retrofit, MFSW retrofit
Malone Stage 2 w/ South Bend stage 3 endurance
Midwest Light Creation's HID headlights
Nero Morg is online now   Reply With Quote
Old February 18th, 2019, 00:01   #8
thompsoncustom
TDI(s): bora
Ok, what's the best way to fix this? I had the IP locked but not the cam.
Old February 18th, 2019, 00:42   #9
Nero Morg
Set the timing like you should. You don't have to take the belt off, but you'll need to set the crank at its timing mark, loosen the tensioner, loosen the cam and fuel pump sprocket, insert the injection pump pin, insert cam lock, set tensioner, then torque pump and cam gears. Bar engine over once, make sure all timing points are lined up.
Old February 18th, 2019, 03:14   #10
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yes, you need to install the timing belt correctly, with the correct tools.
oilhammer
www.cardocautomotive.com
Old February 18th, 2019, 04:26   #11
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Wondering how you rebuilt the turbo too. They are assembly balanced which makes them almost impossible to take apart and have the balance stay in tact.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline   Reply With Quote
Old February 19th, 2019, 01:12   #12
thompsoncustom
TDI(s): bora
Well hopefully being off the pistons didn't touch the valves but it sounds fine when running.
I will buy the right tools for the job and redo the timing before I drive it again, thanks for all the help I have read a complete guides on it now and see where I went wrong.
As far as the turbo rebuild goes, your normal rebuild parts plus a seal plate and exhaust turbine & heat shield(was not straight) I'm sure it's not perfectly balanced but it cant be any worse off than it been for the last 20k miles.
Old February 19th, 2019, 01:38   #13
Nero Morg
Just as a note... Gotta be careful with turbos and rebuilding them. Very slight out of balance really means a lot at 50k rpm turbo speed.
Old February 19th, 2019, 02:46   #14
thompsoncustom
TDI(s): bora
Agreed that's why I replaced the exhaust wheel was kind of surprised it was still in one piece with as bad as the stock one was.
Old February 19th, 2019, 17:06   #15
turbocharged798
The thing the balance is now totally out since you have a new part on it.
Most turbos on the market are component balanced which means each part is balanced on a machine. The hope is that once the parts come together then the whole assembly should be balanced.
The VNT15 used on these cars is a oddity as its assembly balanced. This means that the parts before they get bolted together are NOT balanced. Once the rotating assembly is together, it is put on a VSR balancer and then balanced. This is actually a better way of doing it because the end balance will always be better BUT you cannot service it without re-balancing. Garrett themselves said not to take them apart and won't sell parts for it.
That is in a nutshell why rebuilt turbos do not work well with these cars. Maybe you got lucky and the balance is good, who knows. It might last 300K miles, it might blow up tomorrow. Its a crap shoot.
Extremely hard starting 03 ALH w/ VAG-Com 17656 Code ADVNTURR VW MKIV-A4 TDIs (VE and PD) 12 June 26th, 2015 11:13
99 ALH in, hard starting KevinF VW MKIV-A4 TDIs (VE and PD) 7 September 12th, 2014 17:11
Pls Help. Hard starting, prolonged cranking - ALH TDI-Guy TDI 101 11 July 1st, 2012 17:30
2003 Jetta hard starting, then no starting crash400 VW MKIV-A4 TDIs (VE and PD) 13 March 17th, 2012 17:17
'01 ALH Hard Cold Starting SheeB VW MKIV-A4 TDIs (VE and PD) 24 March 23rd, 2008 20:41
Page generated in 0.19265 seconds with 12 queries
[Output: 127.73 Kb. compressed to 106.58 Kb. by saving 21.15 Kb. (16.56%)]
