Old February 15th, 2019, 17:45   #1
AllenAlic
AllenAlic's Avatar
Fuel Economy: 35 Mpg
Default Brake Fault
So a new issue popped up lately. Whenever I make right turns the brake warning chimes 3 times flashes the brake light. Says Stop and brake fault. Anyone experience this? 05 Passat TDI wagon. BSM delete. 5 spd swap.
AllenAlic is offline   Reply With Quote
Old February 15th, 2019, 18:01   #2
afarfalla
afarfalla's Avatar
worn pads
afarfalla is offline   Reply With Quote
Old February 15th, 2019, 19:41   #3
peiphil
Or the wires going to the brake pads are cracking and breaking !
peiphil is offline   Reply With Quote
Old February 15th, 2019, 20:48   #4
AllenAlic
AllenAlic's Avatar
New pads and rotors couple months ago. This just started. 230,000 on the car. Maybe a wire issue to the pads?
Old February 15th, 2019, 21:13   #5
wtribeflyer
Fuel Economy: Yes
Low on fluid or bad fluid level sensor.
wtribeflyer is offline   Reply With Quote
Old February 16th, 2019, 10:49   #6
zzdiesel
fluid low
zzdiesel is offline   Reply With Quote
Old February 17th, 2019, 08:17   #7
AllenAlic
AllenAlic's Avatar
Fluid level is fine, first thing I checked. Once I pull the wheels and check wiring Iíll reply with the findings. Iím betting the wiring is the culprit. Stay tuned.
Old February 17th, 2019, 10:45   #8
QuickTD
Pad wear wiring faults will only light up the amber pad wear indicator light. I'd check the fluid level sensor wiring and the parking brake lever switch. You should also scan the ABS module, but most abs faults will also light up the "ABS" light.
QuickTD is offline   Reply With Quote
Old February 19th, 2019, 10:44   #9
imo000
imo000's Avatar
Fuel Economy: Good enough
+1. The low pad warning is just a light, nothing more.
imo000 is offline   Reply With Quote
Old February 19th, 2019, 14:50   #10
dogdots
dogdots's Avatar
TDI(s): None
I had that on one of my B5.5's - I swapped the fluid reservoir sensor, mine had an intermittent issue showing low fluid when it wasn't low.
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, 1977 MB 280SL, 1979 Chevy C20 6 banger with 51k original miles, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old February 20th, 2019, 08:49   #11
AllenAlic
AllenAlic's Avatar
So I messed with the reservoir, tapping and shaking it around a bit. Seems to have fixed the issue. I guess the level sensor was the culprit. Been a couple days and no warning.
Brake fault message sschnath VW B5 Passat TDIs 8 December 14th, 2013 08:29
ABS brake fault code Ashmo501 VW MKIV-A4 TDIs (VE and PD) 7 October 23rd, 2013 09:42
Brake Fault Gaggu P Ontario 7 December 7th, 2008 15:37
stop brake fault #9 brettnjess OBD Scanners 1 March 5th, 2007 07:57
Brake switch fault code dieselUFO VW MKIV-A4 TDIs (VE and PD) 1 April 7th, 2005 21:12
Page generated in 0.13178 seconds with 11 queries
[Output: 98.03 Kb. compressed to 82.59 Kb. by saving 15.44 Kb. (15.75%)]
