Old February 15th, 2019, 17:36   #1
BakoTDI
BakoTDI's Avatar
Default Nozzle and clutch upgrade: need guidance
So I need a new clutch for my ALH Mk4 Jetta. I have the stock turbo but I need to replace my nozzles. Iím in desperate need of guidance on this.
I canít upgrade turno at this time so what options might I have in order to be able to support a possible turno upgrade in the future?
Been considering these:
SBC stage 2 endurance or daily
DLC 764 nozzles
Kerma offers different calibration stages for the nozzles as well. Thatís something else Iíd like some assistance on.
With this possible setup, will I need a tune? If so, I need some light shed on me on this issue.
Anyway! Thanks and I appreciate your input.
99 Canyon Red Pearl MK4 Jetta, 5-spd, South Bend clutch Stage 2 Endurance, Firad P502 nozzles, EGR delete, Stage 3 Malone Tune coming up...I'll eventually get to a bigger turbo
BakoTDI is offline   Reply With Quote
Old February 15th, 2019, 18:36   #2
Nero Morg
From personal experience, you can rock DLC520'S with a stock turbo, but as soon as you do a tune, you'll definitely need to do the clutch. Good thing you're in the market for one already!
Since you have to stock 10mm pump, you could probably get away with running the DLC764s without upgrading the turbo.
I would definitely advise getting a tune. You'd probably sit at about a stage 2.
As for the clutch, I've heard the stage 2 dailys have oem similar clutch effort. I can personally testify the stage 3 is at least double the effort. Almost feels like mechanical linkage clutch.
2003 Jetta Wagon silver- DLC520 VNT15 11MM pump 5 speed
ESP retrofit, MFSW retrofit
Malone Stage 2 w/ South Bend stage 3 endurance
Midwest Light Creation's HID headlights
Nero Morg is online now   Reply With Quote
Old February 15th, 2019, 19:00   #3
BakoTDI
BakoTDI's Avatar
Awesome! Will using Daily stage 2 be ok with an upgraded turbo later on? Or should I go with the Endurance to be set in case I do go to VNT17 or Warner S7?
What is the difference between the Kerma tuning and the Malone tuning?
I get that tune stage 2 is good for my stock. What about staging on the nozzle calibration?
Old February 15th, 2019, 19:15   #4
Nero Morg
From what I've read, stage 1 is good for stock, stage 2 is better with nozzles. As for who you use as a tuner, it all comes down to preference. I used malone, but that's because the dealer I used locally is an authorized vendor of malone.
As for the stage 2 clutch, I've heard it'll handle a 17 turbo just fine. Only reason I went with stage 3 is because my stock was slipping too badly and it's all they had in stock at the same local vendor.
Old February 15th, 2019, 19:40   #5
STDOUBT
STDOUBT's Avatar
Bako here are a couple very informative links:
http://dbwllc.net/
https://malonetuning.com/ecu-tuning/...gen/tdi/ve-tdi
2003 Jetta TDI 1.9L 5-speed
All Stock except: Ventectomy
STDOUBT is online now   Reply With Quote
Old February 15th, 2019, 19:57   #6
Rrusse11
"different calibration stages for the nozzles as well. Thatís something else Iíd like some assistance on."
In a word, don't. Set 'em to stock 220/300 bar. DLC764s are big without a major turbo upgrade.
Idparts has Firad 502s (.216) which are plenty big enough. That and a VNT17 down the road make a great snappy
daily driver, that should deliver good FE.
The Southbend stage 2 Endurance is a great clutch in my experience.
A touch more pedal effort than stock, but after 10 minutes of driving
you'll never notice it, and it'll take any tune upgrade you're ever likely to get.
"Stages" of tune is all a bit relative. Depends on what you're after.
My $.02 FWIW.
RC Stage 4: 11mm pump, 17/22, .230 nozzles, 3barMAP,EGR Delete, PD150Intake,2.5" Exhaust: Koni Sp Reds, Wagon Springs, ~1"/2"lift:VR6 fr swaybar, Top strut & rear tie bar: 215/55ZR16 GMax AS05's, 10mm/20mm spacers, 35# @: skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: : VR6 fr Brks:
Rrusse11 is offline   Reply With Quote
Old February 15th, 2019, 20:52   #7
mrfiat
Fuel Economy: 38.5 mpg (in town - trying to improve it)
I have the "Sachs Power Clutch for TDI with G60/VR6 Flywheel" and I love it. Very little effort to press down the clutch pedal. No slippage yet with my stage 4 Malone tune.
mrfiat is offline   Reply With Quote
Old February 15th, 2019, 21:10   #8
BakoTDI
BakoTDI's Avatar
Iím looking for a reasonable setup with my stock turbo that will also work with an upgraded turbo down the road.
Feedback so far is that SBC Stage 2 is a good option with a stage 2 tune (a must) and stock calibration (stage 1) on nozzles is good enough for the DLC764s, WITH my stock turbo.
Now this: will the Daily vs. the Endurance make a big difference?
Old February 15th, 2019, 22:58   #9
Nero Morg
I think the only difference between the two is you get a few extra ponies out of the one clutch, and the $$$.
Going with the nozzles, clutch, and tune, you are definitely opening the gateway to better mods. Next step after that would be bigger turbo, bigger exhaust, ported intake, EGR shennanigans...
You can always email Malone or call Kerma and chat at them about what you wish to accomplish, and they'll give you suggestions for it. I personally would go with the injectors you are already banking on getting, clutch, tune, then start saving for the turbo. Without the tune you may smoke quite a bit, unless you severely turn down the injection quantity.
Old February 16th, 2019, 04:07   #10
How many miles on your '99? Original clutch and flywheel? If it's original and not too worn it will be fine with nozzles and a tune. The LUK kits on '99.5 cars was stronger than kits on later cars.
My advice would be to get some .205 nozzles (like the Firads we sell, shameless plug) and have a local Bosch shop set them up. Much less expensive. And send your ECU to Rocketchip to get it socketed (need to do that on '99.5s) and a Stage 3 tune. That's a strong setup. I ran that in my first '99.5 Golf on track days with the OE clutch and it worked great.
2002 Jetta wagon, 384K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 260K; 2011 335d, 60K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old February 16th, 2019, 06:07   #11
WildChild80
WildChild80's Avatar
I have a Stage 2 endurance in my 01 and the pedal feel was lighter than stock and my 2000 with a stock and is also heavier than the endurance in the 01. It handles every bit of torque my 01 makes with all the goodies on it.
I've heard great things from the G60 setup but have never ran one.
South bend has impressive customer service and completely stands behind their products. I had an issue bedding or seating my clutch and within an hour they had replied, apparently I wasn't driving it hard enough...after that it's been Rock solid for almost 50k miles.
Sent from my Pixel XL using Tapatalk
WildChild80 is online now   Reply With Quote
Old February 16th, 2019, 06:53   #12
BakoTDI
BakoTDI's Avatar
I got about 280K, not original clutch and flywheel but it was replaced along with transmission about 14 years ago. I might go with the local shop idea. Not sure I can deal with the downtime, since it's my daily driver. I guess I still have to send it out for tuning anyway. Might have to consider this too.
Old February 16th, 2019, 18:57   #13
Rrusse11
Bako,
Buy a set of injectors and an ECU. No downtime, other than installation when they return. Do have the immobiliser deleted on
the ECU, just make sure the numbers match. Plug and play, should be less than $200 for both. A couple hours to install if you're at all handy.
Depends on what your downtime is worth.
Old February 16th, 2019, 18:59   #14
BakoTDI
BakoTDI's Avatar
Woah! Ok, you threw me a curve ball! Buy an ECU? Have not heard of this route! Can you please explain? Or DM me, that works too
Old February 16th, 2019, 19:06   #15
Nero Morg
I think it's so you can use a 2000+ ecu with your existing harness and be able to flash new tunes via the OBD2 port. Your car you currently can't.
Edit: After some quick searching, 98 (New beetle TDI's) and 99 all ALH's had a 80 pin ECU, 2000-2003 had the 121 pin ECU's, so it's not just plug n play. Dern.
Nozzle upgrade..... drew_killmeyer TDI Power Enhancements 5 June 21st, 2018 17:03
Nozzle upgrade 2012a3tdi TDI Power Enhancements 18 January 20th, 2017 16:22
Nozzle Upgrade jbourke367 TDI Power Enhancements 1 August 14th, 2014 23:21
Help me. 0.216 nozzle upgrade Onur Fatih TDI Power Enhancements 7 November 4th, 2013 19:38
Injector nozzle upgrade? muhibmc TDI Power Enhancements 8 February 21st, 2012 11:10
Page generated in 0.17166 seconds with 11 queries
[Output: 136.51 Kb. compressed to 114.71 Kb. by saving 21.80 Kb. (15.97%)]
