Old February 8th, 2019, 06:42   #1
duke21
TDI(s): 2.0 TDI BMN
Fuel Economy: 7.0L/100km
Default GTB1756vk in BV43 housing
I would only swap exhaust manifolds. So can i take BV43's exhaust housing from CR110/136/140/143 engines and fit GTB1756 core inside. Or if this does not work, can i take exhaust housing of GT1749vc?
duke21 is offline   Reply With Quote
Old February 8th, 2019, 12:46   #2
adamss24
Fuel Economy: 35-45mpg
Doesnt work... They are different manufacturers and design...
adamss24 is offline   Reply With Quote
Old February 9th, 2019, 11:42   #3
duke21
TDI(s): 2.0 TDI BMN
Ok maybe mixing KKK housing and Garrett turbo doesnt work, but should 1749's housing with 1756...
Old February 12th, 2019, 02:44   #4
shanky887614
TDI(s): vw caddy arl
wouldnt work.
the gt1749 and the gtb's have completly different internals.
the gtbs have a nozzle cage that is what is machined to fit the exhaust housing.
the gt1749 exhaust housing is machined to fit the exhaust wheel
Sent from my ASUS_X00ID using Tapatalk
shanky887614 is offline   Reply With Quote
Old February 12th, 2019, 03:22   #5
duke21
TDI(s): 2.0 TDI BMN
Isnt GT1749VC 3rd gen VNT? So same as GTB1756...
Old February 12th, 2019, 05:08   #6
Yucca
I think GTB1756VK will bolt on to GT1749VC exhaust housing.
Yucca is offline   Reply With Quote
Old February 12th, 2019, 18:31   #7
Bambaataa
Fuel Economy: 47Mpg
I believe this has already been done by someone here...
Bambaataa is offline   Reply With Quote
Old February 13th, 2019, 03:50   #8
duke21
TDI(s): 2.0 TDI BMN
Thank you all. So not need for machining exh. housing to fit?
Old February 13th, 2019, 08:06   #9
Bambaataa
Fuel Economy: 47Mpg
Image i posted is a 1756 in a 1749 exhaust manifold. I don't know of a BV43
Old February 13th, 2019, 20:00   #10
adamss24
Gtb1749vc turbochargers are not easy to find, you better off with a gtb style log manifold made out of 3mm stainless steel bends...
Old February 13th, 2019, 22:26   #11
turbobrick240
turbobrick240's Avatar
Maybe a bv43d would fit the bv43a/bv43b exhaust housing.
Old February 14th, 2019, 01:03   #12
duke21
TDI(s): 2.0 TDI BMN
I dont believe in custom made exhaust manifolds any more, that is the reason to try have stock one. Minimal chances for leaks and cracks...
Old February 14th, 2019, 12:57   #13
Yucca
I think GTB1756VK fit also to GT(B)1646V manifold...
GT1749VC is 16V manifold so 1646V is way to go if you need 8V manifold.
Old February 15th, 2019, 00:48   #14
duke21
TDI(s): 2.0 TDI BMN
i suppose i cannot use BKD's gt1749va's exhaust housing on BMN engine (turbo positioned up side). Bolt pattern seems ok...
Old February 15th, 2019, 11:40   #15
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
No, wont work. Bolt pattern is asymetric, so you cant flip around.
If you have BMN engine, you have GT1749VC turbo which is Gen 3 VNT with seperate nozzle cage like on GT1756VK.
Bad thing about it: You cant use the 1756VK because the VNT lever arm is on the wrong side, so you would need to swap over all the 1756 internals to the 1749 CHRA and have the turbo balanced and afterwards VNT calibrated.
Aslo the 1756 is not the biggest possible GTB17 turbine.
But on the other hand, those BMN engines are not the best for tuning anyway. Way to much problems with Siemens PPD injectors...
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
WTB GTB1756VK exhaust housing Tylenol Private TDI Items for Sale/Wanted 2 February 9th, 2018 07:34
bv43-109 vs bv43-189 Kody TDI Power Enhancements 4 September 28th, 2017 12:41
Wanted: GTB1756VK exhaust housing or bad turbo Kevinski4 Private TDI Items for Sale/Wanted 1 July 1st, 2013 16:56
bv43 for gtb1756vk? Q5Freak TDI Power Enhancements 11 December 24th, 2011 20:56
Busted 02J housing...how hard to transfer internals to new housing? gaddman VW MKIV-A4 TDIs (VE and PD) 5 June 12th, 2010 05:59
Page generated in 0.15396 seconds with 11 queries
[Output: 119.79 Kb. compressed to 99.27 Kb. by saving 20.52 Kb. (17.13%)]
