Old February 2nd, 2019, 08:28   #16
yahmon
Originally Posted by adjat84th View Post
OP says flooring it in 6th gear at 70mph (near 2k rpm) is causing vibration. That's peak torque. If the clutch was slipping, they would see RPMs go up considerably with no matching acceleration...not a vibration.
mercdude, stock flywheel runs around $500. A Sachs upgraded DMF (with clutch and pressure plate) is right around $1k. Labor on this should not be more $600-$800 for someone familiar with these cars. Are there any trusted TDI mechanics in your area? They may be able to tell you for sure if it's the flywheel or not.
If your tuner has already reduced peak torque and that helped slightly, to me that points right at the DMF.
Mine does the same as his, it is like a shudder and not an rpm runaway, likely something caused by clutch and DMF
yahmon is offline   Reply With Quote
Old February 2nd, 2019, 08:33   #17
yahmon
Originally Posted by Rrusse11 View Post
"just downshift at highway speeds because I was lugging my tdi at 2k rpm. Huh???"
You've now got a different engine, learn to drive it properly. Keep it
in the mid 2's and stop lugging it. Get a SMF clutch, I highly recommend the SBC stage 2 End,
and you'll probably need a Fluidampr as well.
That's what I had to do with my Mk6.
You're throwing more power at the stock setup, this is
the slippery slope of modding, buying a tune is only the beginning.
An LSD is a great addition to any car IMO, but it gets expensive in
a hurry. Adding power is the ez part, getting it on the road efficiently and smoothly is the tricky part.
My $.02
They pull hard from 1800 rpm, that's what they were meant to do from factory. they also were made in 170, 190, 240hp factory versions. a simple clutch upgrade should cure this.
Old February 2nd, 2019, 10:25   #18
Rrusse11
You have a kerma tune too? My mk6 with a cr170 turbo dynoed around 180Whp and 300'#s. I was Jeff's (Rocketchip) first tune with that turbo.
Never had a shudder, but the DMF went out. Pulling hard from 1800rpm in 6th was never something I did. I dropped it into 5th.
Motor was much happier, and the car was quick.
Read this thread for other's opinions;
http://forums.tdiclub.com/showthread.php?t=495351
RC Stage 4: 11mm pump, 17/22, .230 nozzles, 3barMAP,EGR Delete, PD150Intake,SMIC,2.5" Exhaust: Koni Sp Reds, Wagon Springs, ~1"/2"lift:VR6 fr swaybar, Top strut & rear tie bar: 215/55ZR16 GMax AS05's, 10mm/20mm spacers, 35# @: skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: : VR6 fr, TT rr Brks
Rrusse11 is online now   Reply With Quote
Old February 2nd, 2019, 10:47   #19
yahmon
different tune but same symptom and different gear. Mine will do it in first if I launch hard and also in 4th from 1800 to 2000.
Old February 2nd, 2019, 13:53   #20
Yourbuddysatin
Fuel Economy: 32-35mpg
Welp now I’m sold on not tuning my CJAA for a good while. Plus not voiding that warrenty.
Yourbuddysatin is offline   Reply With Quote
Old February 2nd, 2019, 15:06   #21
yahmon
Where is your sense of adventure?
Old February 2nd, 2019, 19:22   #22
Yourbuddysatin
I know I’m a disappointment ....I’ll leave all the goodies from my golf. It will be fun. Wife calls my mk6 a dads car...now I feel old.
Old February 2nd, 2019, 21:01   #23
mercdude
You shouldn’t be discouraged. Like others have said, the lower level tunes work flawlessly.
Btw Kerma persuaded me against a turbo upgrade because it wouldn’t give any more power than the tune, only lower egt’s. And according to kerma the tune is giving 170/350 to the wheels. I haven’t dyno’ed to verify but it feels damn quick and will spin wheels hard in first and second gear. Almost scary in the rain tbh. Hence the wave trac lsd.
mercdude is online now   Reply With Quote
Old February 2nd, 2019, 21:06   #24
mercdude
Exactly. If we were discussing a 1.8t then I’d agree with lugging, but these tdi’s are like the old pushrod v8s in how they deliver power. IMO Dropping down a gear is a way to cover up the symptom of something else going on - works yeah, but you shouldn’t have to do it.
Old February 10th, 2019, 14:02   #25
mercdude
Quick question: has anyone that shares the same vibration issue tried to replicate the vibration with and without traction control turned on? I had some replication of the vibration in the rain in 3rd gear and I then without the traction control I couldn’t replicate. So wondering if that’s the issue -
Thoughts?
Old February 10th, 2019, 14:04   #26
DAKOTAKIDD
For my shutter/vibration—-I don’t have traction control on my car
Cheers
DAKOTAKIDD is offline   Reply With Quote
Old February 13th, 2019, 09:19   #27
mercdude
Cheers
You have a mk6 cr tdi, correct? My ‘13 jsw has traction control as ASR - Seems like every vag product would have some sort of tc by this point.
Old February 14th, 2019, 17:49   #28
DAKOTAKIDD
Mine is an MK4. But I Experience the same issue just I don’t have traction control.
Old February 14th, 2019, 18:14   #29
sootchucker
sootchucker's Avatar
TDI(s): 2015 Golf
Fuel Economy: Good
the shudder is present in my car as well, malone 2.0.
no big deal, i "drive around" it.
Who says a Jetta can't roll coal???
sootchucker is offline   Reply With Quote
Old February 14th, 2019, 20:50   #30
Owain@malonetuning
Worst case Ontario tuning is fully adjustable on our end, can pull out torque by gear and only for ~200-300rpm sections which is usually enough.
Wide open from lower RPM in 5th/6th is usually the main culprit.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Page generated in 0.16703 seconds with 11 queries
[Output: 123.62 Kb. compressed to 103.34 Kb. by saving 20.28 Kb. (16.41%)]
