Old February 19th, 2019, 09:33   #31
k_pt
k_pt's Avatar
TDI(s): VW MKIV TDI
Ok, I was going to point out the vnt system, simply because I've noticed when you have underboost issues on these engines, whether it's due to the turbo being too big, faulty vnt, or the rod just not well adjust. It's much more noticeable on lower gears.
I have a hybrid turbo, with a bit of underboost and it's more noticeable on lower gears. Probably ECU doesn't have time to adjust the vnt since lower gears are more quick completing the rpm range.
Follow me on some mechanics works https://www.instagram.com/kptgarage1986/
k_pt is offline   Reply With Quote
Old February 19th, 2019, 17:39   #32
[486]
TDI(s): 02 golf ALH
Originally Posted by FixItDaily View Post
and I spent $1400 for the turbo and new oil feed line.
I have that into my MIG welder, all 5 turbos that have been on the car, and all the iterations of piping and manifolds that have been on the car.
[486] is offline   Reply With Quote
Old February 19th, 2019, 21:26   #33
FixItDaily
TDI(s): 2003 Golf
Yeah... I got the VNT17 Plus. I want this car to run right. I’m not even sure that the turbo was the problem, I am worried though that the problem caused the turbo failure. I want to get this thing worked out so that I can enjoy it. I am tired of having to replace parts. ��
FixItDaily is offline   Reply With Quote
Power loss under hard acceleration. Dobsondweller TDI 101 17 January 31st, 2017 07:27
2006.5 Jetti TDI- hard "buck" under moderate acceleration whodom VW MKIV-A4 TDIs (VE and PD) 2 August 23rd, 2016 17:03
sudden power loss under hard acceleration tstdimk4 TDI 101 1 June 11th, 2009 12:07
Smoke on moderate acceleration geistfahrer VW MKIV-A4 TDIs (VE and PD) 1 July 14th, 2005 14:08
Pulsing under moderate acceleration AlastairUK VW MKIV-A4 TDIs (VE and PD) 3 November 14th, 2003 17:59
Page generated in 0.10827 seconds with 11 queries
[Output: 61.84 Kb. compressed to 56.20 Kb. by saving 5.64 Kb. (9.12%)]
