Old January 27th, 2019, 17:47   #1
Yourbuddysatin
Fuel Economy: 32-35mpg
Default 2012 CR Jetta overheating
Hey guys,
Iíve been tinkering with a 2012 Jetta tdi. It has an overheating problem but I have not a clue why. Blows nice hot air so I doubt the t stat is stuck. Changed the water pump and all that so I know thatís ok. Upper rad hose gets hot and lower is cool. Fans come on. No pressure in the system from what I can tell and never boils over in the expansion tank. I changed the temp sensor just to see if that would be it and its still getting hot. It will go up to 100c at idle and climbs over 122c(coolant light comes on) and rising when driving. My next step is to pressure test the coolant system. Anyone else run into a similar problem?
Yourbuddysatin is offline   Reply With Quote
Old January 28th, 2019, 04:02   #2
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
No pressure in the system sounds like air. The water pump cant build pressure or circulate coolant pumping air.
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old January 28th, 2019, 04:17   #3
Yourbuddysatin
Sorry I meant it’s not over pressure. It bleeds pressure off when i unscrew the cap.
Old January 28th, 2019, 05:27   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The thermostat has nothing to do with the heater. Although it is rare, I'd replace the thermostat first. Which, I have bad news for you, is a time consuming process. I'd also get the plastic pipe that likes to break, and the oil filter stand gasket.
oilhammer
www.cardocautomotive.com
Old January 28th, 2019, 06:04   #5
Yourbuddysatin
Oh Christ full front end removal?? Just my luck. So if the t stat isn’t opening I’ll still get heat?
Old January 28th, 2019, 06:55   #6
oilhammer
oilhammer's Avatar
Coolant is ALWAYS flowing through the heater core, regardless of what the thermostat is doing. Thermostat controls the flow of coolant through the radiator.
You can just pull the lock carrier assembly into service position, you do not have to take it all the way off, I just do it that way because it is easier.
The plastic tube requires you to remove the oil filter stand, as it is attached underneath and wraps around to the bellhousing area.
oilhammer
Old January 28th, 2019, 07:42   #7
Yourbuddysatin
Thanks oilhammer. I appreciate the info. I think I will pressure check the system make sure there is not a leak anywhere then aim to change the thermostat.
Old February 1st, 2019, 05:11   #8
740GLE
Having radiator hose hot on one side and cold on the other should have been the red flag for you.
Old February 3rd, 2019, 09:51   #9
adamss24
Fuel Economy: 35-45mpg
From experience the stats on vag group cars get stuck allways in the open position so they over cool the engine. I would say a blown head gasket but i would put a new stat and bleed the system just in case!
adamss24 is offline   Reply With Quote
Old February 3rd, 2019, 09:58   #10
turbobrick240
turbobrick240's Avatar
Could also be a blocked up radiator.
Old February 3rd, 2019, 13:52   #11
Yourbuddysatin
It’s torn down now and waiting for parts to come in. Rad is good I checked it and I did a leak down test and it passed with flying colors. I have to say the thermostat is the problem. I will know by the end of the week for sure.
Old February 8th, 2019, 19:37   #12
Yourbuddysatin
All fixed up. New thermostat did the trick. Probably had about 5 hours into the whole deal. No temps over 90c.
Old February 9th, 2019, 13:33   #13
oilhammer
oilhammer's Avatar
Great! Thanks for reporting back.
oilhammer
Old February 9th, 2019, 18:32   #14
D-Cup
With regards to tsat failure - does this tend to be a function of time vs mileage vs runtime?
For example, a car driven 10kmi/yr will have 12yr between tbelt service and therefore have a 12yo tstat.
But someone that drives 20kmi/yr will have 6yr between tbelt service, therefore the tstat will only be 6yo...
Would this make it less likely for one to see a tstat fail “out of turn” since its being replaced at a younger age (as a function of time) even though it’s seeing more mileage/runtime?
D-Cup is offline   Reply With Quote
Old February 9th, 2019, 18:57   #15
Yourbuddysatin
I personally don’t believe it’s a very common problem. A friend buys a lot of these mk6 tdis and this is the first we ran into with a overheating problem. This car is pre emmsions fix also so I think this one was abused.
Used 2012, overheating problem ioghli VW Passat Family (NMS and B7) TDIs (2012+) 18 May 14th, 2017 03:12
Servicing 2012 1.6 tdi cr seat Ibiza EA189 DanGriff TDI 101 2 February 19th, 2016 09:23
2012 (MK6) Jetta TDI (2.0L CR) - interior (cabin) heating sucks & future upgrade Ckoskie VW MKVI-A6 Jetta Sedan (~ 2011+) 10 December 9th, 2013 12:27
Digi CR TDI Module 2009-2012 FOR SALE BIGCUMMINSTDI Private TDI Items for Sale/Wanted 0 April 24th, 2013 23:09
Page generated in 0.16102 seconds with 11 queries
[Output: 120.35 Kb. compressed to 99.69 Kb. by saving 20.66 Kb. (17.16%)]
