Old January 25th, 2019, 05:44   #1
Deltaman
Default Which cylinder heads will fit my DDAA engine?
Hello folks,
I've bought a DDAA engine, from a VW Passat 2016 190HP.
Unfortunatly the seller didnt told me that the head was damaged.
I'm searching for an replacement cylinder head. The part number of the original cylinder head is: 04L 103 064 J. And is hard to find.
I've found a lot other cylinder heads with exactly the same part numbers, but different end letter at the end, for example like: 04L 103 064 F.
The camshafts are the same. The part number of mine is: 04L 103 308 C.
Now is my question: can I swap the cylinderhead of mine (04L 103 064 J) with an other CR engine? Or which ones will fit, besides the original one of course.
Thank you very much!
Deltaman is offline   Reply With Quote
Old January 25th, 2019, 07:10   #2
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Hi, you can puy any cyl head from the 150-184 hp engine since they are identical.
04L103064E and C , this is good for you
Are you making the swap to the 190hp engine? Intending to tune it or leave it stock?
Curious how it goes. I am considering myself an engine swap like that.
What is wrong with the cyl head? You should be able to repair it.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is online now   Reply With Quote
Old January 26th, 2019, 03:03   #3
Deltaman
So basically I can use any 2.0 CR cyl head, they are all the same. (To be clear 1.6 isn't the same? The reason I doubt is because the cams and cover do.)
The reason i want to swap out the head is because the engine comes from a wrecked car, 1 injector was hit and broken. Also the cams seized due water damage. So I don't want to rebuild the head and want to swap it over from an other engine due the rebuild costs.
My BKD makes 185HP with a chip and straight exhaust. My intention is to swap the 190hp, delete all of the EGR and DPF stuff. Then a software tune. My Goal is +/- 240hp if possible.
Old January 26th, 2019, 04:49   #4
Macradiators.com
You can do 235-240 on stock pump. To go to 300 you need cp3 upgrade + turbo.
There is a lot of wiring to do the swap.
CP3 Upgrade
Old January 26th, 2019, 05:08   #5
Deltaman
Any info is welcome.. This swap is new for me and I'm gathering information everywhere i can.
What i've been told is that i need the engine wiring harness and ECU of a random CR 2.0. One side goes to the engine, while the other fits on the plug which comes from the car it self.
Can you tell me which one i can use? Or do i need to stick with a DDAA ECU and harness?
Old January 26th, 2019, 08:02   #6
Macradiators.com
These new engines have secondary oil circuit controlled by ECU so you need ecu +wire harness from the engine you bought.
Probably other things as well, so get that ecu and harness.
CP3 Upgrade
Old January 28th, 2019, 01:42   #7
Deltaman
Are you sure you don't mean secondary water circuit?
Old January 28th, 2019, 02:53   #8
Macradiators.com
To keep it short you need engine plus ecu to control it.
Sent from my SM-G935F using Tapatalk
CP3 Upgrade
Old January 28th, 2019, 03:17   #9
Deltaman
I'll source them as soon as possible! First i need to fix the head..
Thanks for your help.
Old February 12th, 2019, 01:47   #10
Deltaman
I've bought me a Golf Mk7 GTD CUNA engine
I'm going to swap over the 190HP turbo on the CUNA engine.
The DDAA turbo is watercooled, so i'm going to swap the hoses of the DDAA engine over to the CUNA engine.
Can you maybe help or supply me with info about PD to CR swap wiring?
2.5 V6 cylinder heads, how to tell them apart? SyncroS8 TDI 101 3 May 1st, 2012 05:28
Difference in cylinder heads... best one? chhhris VW MKIII-A3/B4 TDIs 2 June 29th, 2010 21:29
Blown cam, cylinder heads damaged - fix or replace engine? breitbarth VW MKIV-A4 TDIs (VE and PD) 19 November 3rd, 2009 18:42
Interchangeable cylinder heads? ANDYCQ20V TDI 101 7 January 18th, 2008 13:25
A-3 / B-4 Cylinder Heads Herm TDI VW MKIII-A3/B4 TDIs 11 January 8th, 2007 05:12
Page generated in 0.12693 seconds with 11 queries
[Output: 97.30 Kb. compressed to 82.57 Kb. by saving 14.73 Kb. (15.14%)]
