Old September 8th, 2016, 19:18   #31
red16vdub
red16vdub's Avatar
Unless I'm mistaken (which I am often) 2620 bar less one atmosphere is 23.7 PSI, give or take. I've always understood that the safe boost limit for a VNT-17 is 22-24 PSI. Both turbos mentioned here were running more than that.
26psi was recommended for what my mods were at that time. I have egt/boost gauges and certainly didn't exceed or reach what the car was tune for. The turbo blew out the exhaust along with 80% or so of the oil, luckily for me zero engine damage. I cut my losses and dug deep into the piggy bank for a 17/56
Bajan
Mk1 Gti /scIROCco 16v /A6 quattro sport / Mk4 TDI JSW 5spd
17/56 turbo, RC ASV-5+ @ 28psi, 3 Bar Map, 11mm IP, PD Lift Pump, R520's, McNally boost/egt, Euro FIS full screen Cluster, PD 150 Intake/racepipe, PD 150 plastic T.I.P + R32 maf air mods, Kerma 2.5" Fmic, Kerma 3"T-B exhaust/resonator/ Aero turbine muffler, SBC stage 3 Endurance, GLi brakes F/R , GLi axles, H&R Bilstein sports cup kit.
red16vdub is offline   Reply With Quote
Old September 8th, 2016, 19:58   #32
red16vdub
red16vdub's Avatar
Default Catastrophic VNT 17 failure
Pics of the grenade vnt 17
The turbine went out the 3" exhaust .
Bajan
Old September 8th, 2016, 21:04   #33
turbovan+tdi
turbovan+tdi's Avatar
First turbo plate looks legit. To me anyhow.
Old September 9th, 2016, 04:46   #34
red16vdub
red16vdub's Avatar
Yes it does
Bajan
Old September 9th, 2016, 06:22   #35
Drivbiwire
Zehntes Jahr der Veteran
Originally Posted by HelenaTDI View Post
This is what is left of my compressor. I flushed out my IC with a gallon of acetone today. Cleaned all the intake piping as well. Air cleaner looked fine.
Do I trust using the IC or get a new one? I used compressed air to blow anything out afterwards.
Had a cup or so of oil pour out the IC. Where did the other 1qt or so of oil go? Tried running a magnet down my down pipe as far as I could go. Couldn't retrieve the exhaust turbine and shaft. Not sure if it blew out the tail pipe. I shouldn't have any interferences so maybe it's out.
Compressor stall at the Exducer, tips are all missing....
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old September 9th, 2016, 06:26   #36
Drivbiwire
Bajan
Stop focusing on the 26psi, were you flowing enough volume at 26psi to prevent surge/stall of the compressor?
a bigger turbos isn't going to necessarily solve it if you haven't improved the volumetric ability of the engine to allow the increased capability to pass thru it.
Old September 9th, 2016, 06:40   #37
Drivbiwire
Centrifugal compressor stall patterns..
Old September 9th, 2016, 07:10   #38
QuickTD
It should be noted that 26psi is a ~2.8 pressure ratio. Off the top of the map (compressor rpm) for the VNT17 at just about any mass flow.
QuickTD is offline   Reply With Quote
Old September 9th, 2016, 07:21   #39
Drivbiwire
Here's the map, 1749.
Its that dashed line on the front end of the map that blew that turbo...
Old September 9th, 2016, 09:10   #40
red16vdub
red16vdub's Avatar
I'm not quite sure how to answer that , but will say the only changes made was different turbo and retuned.
Bajan
Old September 9th, 2016, 23:08   #41
Nevada_TDI
Honestly, I am confused myself; how could a turbo be making that much boost and have an issue with stall? I could maybe understand a gasser with a bad b.o.v., but our diesels don't have throttle bodies.
Nevada_TDI is offline   Reply With Quote
Old September 10th, 2016, 10:30   #42
turbovan+tdi
Tips are missing because they were machined off by the compressor housing.
Can't see how it would stall as well.
Old September 10th, 2016, 12:27   #43
AnotherPerson
TDI(s): 1999 Beetle
Kinda related here. I have a vnt17 stock tune. I won't have any stall issues will I? I don't do hard launches
AnotherPerson is offline   Reply With Quote
Old September 10th, 2016, 17:42   #44
Nevada_TDI
Not likely with a stock tune .
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Old September 10th, 2016, 18:07   #45
AnotherPerson
TDI(s): 1999 Beetle
Thx. Just making sure since it may be after new years for the tune now.
Catastrophic Engine Failure iankurek VW MKV-A5 Golf/Jettas 13 July 7th, 2014 12:29
Nearly Catastrophic LCA failure sk8rdi16 VW MKIV-A4 TDIs (VE and PD) 4 March 3rd, 2011 07:49
Turbo Failure - Replace with KP-39 or VNT-17? nbtenhaken VW MKIV-A4 TDIs (VE and PD) 18 December 4th, 2010 11:04
Catastrophic turbo failure. bennychapman TDI 101 8 January 31st, 2006 06:58
Catastrophic failure BrokenBlock VW MKIV-A4 TDIs (VE and PD) 8 February 10th, 2005 10:54
Page generated in 0.16670 seconds with 11 queries
[Output: 134.13 Kb. compressed to 112.63 Kb. by saving 21.49 Kb. (16.02%)]
