Old April 25th, 2015, 17:11   #1
audiphile
audiphile's Avatar
Default EURO CAR with ATJ engine - no OBD protocol - how to pass emissions
Customer of ours has a 1/98 production Passat with the ATJ PD115 engine in it. It's a German market car, so the ECU does not have the OBD2 compatible protocol.
State of NJ now requires all cars to pass the basic OBD2 scan for ready monitors, which this car cannot show. In fact, the state of NJ cannot connect to the ECU at all (though all our scanners pick it right up, albeit "NON OBD")
I've got e-mails to Rocketchip and Malone (neither replied yet) - but fishing for some ideas.
We were thinking of maybe getting an ECU from a US Market PD car and adapting it to the older emissions/turbo equipment of the ATJ engine (older style EGR valve and turbocharger vane control, like in the ALH)
Would love to hear your thoughts!
audiphile is offline   Reply With Quote
Old April 25th, 2015, 17:51   #2
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
I am pretty sure a tuner should be able to update the ECU file so it supports OBD2.
I have to ask, how did this car get into the US?
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline   Reply With Quote
Old April 25th, 2015, 20:32   #3
audiphile
audiphile's Avatar
Thanks! hoping one of the tuners will reply. what other tuners do folks trust with TDI's nowdays?
We have no idea how this car got into the US, but we're thinking it's a diplomat's car that was supposed to be taken out of the country or crushed, but was somehow resold. It's actually pretty cool. Plain cloth seats, climatronic, rear manual windows, 6-speed manual. I'd totally drive this every day!
Old April 27th, 2015, 05:03   #4
50harleyrider
Good luck making this cool car legal
50harleyrider is offline   Reply With Quote
Old April 27th, 2015, 07:16   #5
audiphile
audiphile's Avatar
so APR cannot help.. Malone and Rocketchip not replying. If anyone knows any tuners, or if you can help reach someone at the tuners above - please help!!!
Old April 27th, 2015, 07:49   #6
QuickTD
Mike at TDtuning may be able to help. TDtuning.com
QuickTD is online now   Reply With Quote
Old April 27th, 2015, 08:18   #7
audiphile
audiphile's Avatar
no contact information at all on his site....
Old April 27th, 2015, 08:48   #8
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Check with TDIClub member JFettig he has a '98 TDI and he knows a thing or two about ECUs.
http://forums.tdiclub.com/showthread.php?t=291294
-George Bernard Shaw
Old April 27th, 2015, 17:03   #9
turbocharged798
I am thinking a MSA15 ECU from a 99.5 Jetta/golf/NB TDI should plug in and work but not 100% sure. I know I had a rocketchip ECU a while back that had a euro passat tune on it and it was working on my 99.5..
Old April 27th, 2015, 18:11   #10
JFettig
JFettig's Avatar
I'm not convinced its not readable because of the ECU but because of some wiring issue. You could try reading it with direct connection to k-line, you'd have to find the proper plenum plug and whatnot to tap into, to rule that out.
turbocharged798 - its not a VE TDI, its an early PD. Its EDC15.
I've sent you a couple things to check via e-mail.
JFettig is offline   Reply With Quote
Old April 28th, 2015, 02:53   #11
KERMA
KERMA's Avatar
this ecu model year definitely has OBD capability. It can be bench tested to verify functionality. (sometimes the ecu itself is defective) Worse case, if the wiring is bad, you can rig up the wiring to make the OBD plug work, by tapping into the wiring harness coming off the ecu and running wires directly to the plug.
readiness is no problem. They all have it in the 98 model year, just need to have it switched on to say "welcome to the USA"
Some of the early 115 hp cars had two chips (32 pin PPLCC) instead of 44 pin so it may not be obd flashable. But the necessary modifications can definitely be made on the workbench in any case.
HP is for show, TQ is for go.
celebrating http://www.kermatdi.com since 2002
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Niels Bohr
KERMA is offline   Reply With Quote
Old April 28th, 2015, 18:26   #12
Montezuma
Try Kerma tdi for tuning
Montezuma is offline   Reply With Quote
Old April 29th, 2015, 10:52   #13
audiphile
audiphile's Avatar
bump! would love it if someone could help. Here are some pictures to make it clear what we're dealing with.
This car when I plug in an ALH ECU for testing reasons:
Same car with its native ATJ ECU:
Autoscan:
Code:
VCDS Version: Release 14.10.2
Data version: 20150311
www.Ross-Tech.com
Monday,27,April,2015,14:53:32:32856
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 295510km-183621miles
Address 01: Engine        Labels: 038-906-019-AJM.lbl
Part No: 038 906 019 AJ
Component: 1,9l R4 EDC 0000SG  1060
Coding: 00002
Shop #: WSC 05311
VCID: 5FC66972DDBDC4D9375-4B00
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 D
Component: ABS/ESP front       D36
Coding: 04255
Shop #: WSC 05311
VCID: 346CD6DE04BB3781BA7-513C
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 -  -
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC     C 0.7.0
Coding: 05000
Shop #: WSC 05311
VCID: 21422F8AAB49B229411-5248
1 Fault Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to Plus - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 B
Component: 05 AIRBAG VW5       0003
Coding: 12341
Shop #: WSC 05311
VCID: 3668ECD612C72591843-4B00
Address 17: Instruments        Labels: 3B0-920-xx2-17.lbl
Part No: 3B0 920 822 A
Component: B5-KOMBIINSTR. VDO V25
Coding: 05245
Shop #: WSC 00012
VCID: 1D3A137A973196C9659-515A
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0X2160873
IMMO-IDENTNR: VWZ7Z0X2160873
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN    0001
Coding: 00004
Shop #: WSC 05314
VCID: 70E41ACE30234BA19EF-513C
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 -  -
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 S
Component: 3B Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 05311
VCID: 4E98A4368A577D51AC3-4B00
Subsystem 1 - Part No: 1J1959801D
Component: 3B Tőrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802E
Component: 3B Tőrsteuerger. BF0002r
5 Faults Found:
01329 - Convenience System Data Bus in Emergency Mode
35-00 -  -
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
54-10 - Incorrectly Equipped - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 -  -
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 -  -
Address 56: Radio        Labels: 1J0-035-15x-56.lbl
Part No: 1J0 035 152 E
Component:  Radio             0001
Coding: 00001
Shop #: WSC 05311
VCID: 20442A8EA043BB214EF-4B7C
End-------------------------(Elapsed Time: 04:56)--------------------------
Old April 29th, 2015, 13:33   #14
Frans
TDI(s): Golf MK2 TDI
Probably a conversion, since there were no PD engines before '00 installed into passats. What kind of engine does the VIN show?
Did you try to flash some US mk4 PD software into it?
Frans is offline   Reply With Quote
Old April 29th, 2015, 13:57   #15
JFettig
JFettig's Avatar
Frans, US MK4 PD's all had EDC16.
AJM/ATJ engine matches zallac VW B5 Passat TDIs 2 February 9th, 2014 02:02
ATJ engine/gearbox question sombien TDI Power Enhancements 0 August 7th, 2008 05:06
WTB: 028 906 461 MAF for 2000 ATJ Engine Hasenwerk Private TDI Items for Sale/Wanted 0 May 14th, 2006 17:51
And Toyota now meets Euro VI (SIX!) Diesel Emissions in its New Family Car (Avensis) BeetleGo Non VW Group Diesels 4 February 28th, 2003 06:54
Page generated in 0.17735 seconds with 11 queries
[Output: 132.52 Kb. compressed to 110.47 Kb. by saving 22.05 Kb. (16.64%)]
