Old October 30th, 2013, 08:33   #16
Votblindub
Votblindub's Avatar
Is there any coolant creep?
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Old October 30th, 2013, 08:52   #17
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
Originally Posted by Powder Hound View Post
Or the quickest easiest test of all, which is to use a screwdriver or similar metal implement and just short the wire fastened on top of the fuel cutoff solenoid to the IP body. Shuts off in 1 second or less. That's the current method of shutdown for the moment.
That rules out my theory about the fuel cutoff solenoid getting stuck in the ON position. Your fuel cutoff solenoid appears to be good. If everything else checks out OK, maybe a problem with the ECU itself?
If the car has a manual transmission, a clutch dump while in 5th gear will shut it down quick.
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Old November 5th, 2013, 08:59   #18
fierodough
TDI(s): Beetle
Fuel Economy: 5.7l/100km
I still think 12V is migrating to the ignition side.
With the key off (and engine keeps runing) push the gas pedal. Does the engine rev more? If so, the ECU is being kept alive by some stray 12V source. If it does not react, you have 12V migrating only to the fuel cut off solenoid.
fierodough is offline   Reply With Quote
Old November 5th, 2013, 11:26   #19
KLXD
Powering the solenoid alone won't keep the engine running. The ECU sets the IQ to zero to shut off the engine. You can take the plunger out of the solenoid and the engine will stop just fine.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old November 5th, 2013, 18:46   #20
supton
supton's Avatar
Fuel Economy: 53/46/33
Is the dashboard still on? Can you drive with the key out?
Maybe it knows it's demise is soon, and it's to live as long as it can... You did say it was an auto, afterall.
'04 Jetta Wagen 5spd GLS, 314kmiles, Koni Red's, SBC stage 2 clutch, VNT17, RC2 sold
'11 Camry base 6spd manual, 95k, wife's
'10 Tundra double cab, 4.6L, 95k, mine
supton is offline   Reply With Quote
Old November 6th, 2013, 05:51   #21
BlueGolfTDI
How's the oil level holding? Maybe the engine is not running on diesel fuel when the ignition is off.
BlueGolfTDI is offline   Reply With Quote
Old November 6th, 2013, 08:50   #22
Powder Hound
Powder Hound's Avatar
If that were the case, shorting the fuel cutoff solenoid to shut down the engine would not work.
The oil level is fine, though.
Can't try driving in key-out mode because removing the key locks the transmission in park. I should get out there and see if the go-pedal changes things.
Old November 6th, 2013, 12:23   #23
KLXD
I missed in the first post that you already replaced the key switch.
So, you kill the engine and disconnect the battery. Now you go to restart and connect the battery. What happens?
Does the dash go through its normal test mode and do the plugs cycle, assuming it's cold enough? Or is everything dead until you turn on the key?
Old January 27th, 2015, 21:15   #24
madmikeismad
TDI(s): 99 Beetle
Ever figure this out? I'm having exact same issue after a tdi swap. Post 46
http://forums.tdiclub.com/showthread...49#post4724449
'02 GTI with not enough trans
madmikeismad is offline   Reply With Quote
Old February 17th, 2019, 07:41   #25
joman100
Hey folks!
My 2005 BEW TDI starts and runs great, but around a month ago the car engine stopped turning off when I turn the key to the OFF position. The only way to kill the engine is to open and then close my door (i dont understand why). Also, if another door is open (for example, if the passenger opens their door before I close mine, the car won't shut off). I need to open at least one door, then have all doors close in order to shut off the engine. So far this isn't actually a problem for me, since I know how to kill the engine, but I would like to resolve this since I know it's not normal.
Any help is greatly appreciated
joman100 is offline   Reply With Quote
Old February 17th, 2019, 08:04   #26
[486]
TDI(s): 02 golf ALH
from limited understanding I'd be looking for anything that takes power from both the load reduction relay and also n109 relay
start pulling fuses until you find the component that is bridging power over
[486] is offline   Reply With Quote
Old February 19th, 2019, 02:22   #27
erreesse
Hi,
I had the same problem years ago, the solution was a diode somewhere near the alternator.
erreesse is offline   Reply With Quote
Old February 19th, 2019, 18:34   #28
wonneber
I couldn't find a diode in the charging system other then those inside the alternator.
There's 2 diodes in the daytime running lights relay.
It might feedback through fuse 5.
Try pulling the relay and see if the problem goes away.
Old February 23rd, 2020, 08:28   #29
Dubdude
I'm having the same issue except the only thing that allows the engine to shut off is if I apply the parking brake before I turn the key off. 02 Golf ALH 5 speed swapped 410k
Dubdude is offline   Reply With Quote
98 New Beetle TDI engine light won't shut off for inspection ecowaters TDI 101 10 December 28th, 2009 20:31
Standed HELP !Shut off engine now won't start air in clear line ?? terrydtdi TDI 101 11 March 31st, 2008 17:48
Replaced Starter, now engine won't shut off warper Ontario 2 October 5th, 2006 07:30
replaced ignition switch, engine won't shut off bigtom111 VW MKIII-A3/B4 TDIs 3 March 18th, 2005 13:32
Alarm Won't Shut Off, Car Won't Start Beagles VW MKIII-A3/B4 TDIs 5 February 9th, 2003 09:03
Page generated in 0.16485 seconds with 11 queries
[Output: 119.51 Kb. compressed to 100.01 Kb. by saving 19.50 Kb. (16.32%)]
