Old February 6th, 2019, 16:50   #91
CarlosVW
CarlosVW's Avatar
Default BV43A install in my 2005 B5.5 BHW
Originally Posted by 50harleyrider View Post
You really should read my build thread. Ebay is full of reinforced silicone reducing 90's, etc to make your install clean. Use t band clamps too. Regular hose clamps won't hold 2 bar of pressure.
I keep blowing my lower elbow out.
Sent from my iPad using Tapatalk
CarlosVW is offline   Reply With Quote
Old February 8th, 2019, 11:06   #92
50harleyrider
Those elbows are available in multi ply. You shouldn't be blowing them out unless you have other issues. Actually failing or coming loose? How much are you boosting?
50harleyrider is offline   Reply With Quote
Old February 8th, 2019, 19:05   #93
CarlosVW
CarlosVW's Avatar
Boosting 28-30#. Theyíre splitting up.
Old February 11th, 2019, 19:57   #94
50harleyrider
I can trade you a stock turbo. PM me
Old March 9th, 2019, 17:29   #95
tims944
TDI(s): 2006 mk5 tdi
hi guys so i did a lot of readint through this thread.
i found this BV43 turbo stock brand new from germany.
im running a FMIC so the plumbing on the 43 is fine dont need the 43a outlet.
anyone run one of these, i dont need 240hp, so frans or xman turbos are a little pricy this is much cheaper?
thoughts?
it will be for a 6 speed RWD BHW project
https://www.ebay.com/itm/Turbolader-...QAAOSw9mpZ5iFW
also please dont buy it out from under me haha...
waiting for comments before buying.
thanks tim
tims944 is offline   Reply With Quote
Old March 9th, 2019, 20:14   #96
G60ING
G60ING's Avatar
Itís worth it, itís a more robust turbo than stock and has great potential,
G60ING is offline   Reply With Quote
Old March 10th, 2019, 09:25   #97
tims944
did you install the stock compressor with basic compressor wheel or did you have one of the known shops swap in different wheels?
thanks im working on finding the exact one i want and just ordering it,
Old March 10th, 2019, 21:39   #98
G60ING
G60ING's Avatar
All stock
How To: R/R B5.5 BHW Alternator Pulley MOGolf VW B5 Passat TDIs 52 May 16th, 2017 01:16
2005 Passat B5.5 (BHW) TDI part out Fireblade16 Private TDI Items for Sale/Wanted 6 September 27th, 2013 23:44
FS: 2005 Passat TDI BHW B5 Oil Pan speedeagle Private TDI Items for Sale/Wanted 0 June 15th, 2011 19:23
B5 BHW engine in Europe? got4g63 VW B5 Passat TDIs 6 March 26th, 2010 10:57
B5 Passat BHW engine problems blaz Ontario 10 February 15th, 2009 15:33
Page generated in 0.13437 seconds with 11 queries
[Output: 87.64 Kb. compressed to 75.86 Kb. by saving 11.79 Kb. (13.45%)]
