Old August 25th, 2014, 03:07   #46
Yucca
Originally Posted by Night^Walker View Post
Which is the best set up for VP37 pump. My car is with 12mm pump and DE143 camplate. The nozzles are .341 HFLOX and the best time I`ve got is 11,8sec with 185km/h and 1,65-60ft. The max power is 195kW on 4x4 wheels. With the N2O it is about 235kW.
The question is how to upgrade the pump to deliver more fuel. The car is running up to 5500rpm.
I think you have enough fuel for your setup. Do you have good ported head? Measure your AFR, if you are running rich you need better turbo.
Yucca is offline   Reply With Quote
Old August 25th, 2014, 12:41   #47
Night^Walker
Night^Walker's Avatar
TDI(s): 1,9TDI AHF
The head is ported and AFR measures are not running rich. This is the problem, while I am using the N2O the power is going down after 4700rpm due to not enough fuel. The case pressure is also adjusted, and we installed additional pump in the tank which deliver 2,5 bars pressure to the pump. We are trying to put to the limit this turbo and after that we will try GTX3076 if the fuel problem is resolved .
Golf 2 4motion AHF, Garrett GTB2265VK,Nozzles HFLO-X .341, TDI Meister camshaft, Front mount cooler, exhaust 76mm, 4bar MAP, Air filter HKS, Coilover suspension KONI, Rota Force 17", Integrated Piston Rods, Sachs Performance Clutch. Powered by TST-Racing Bulgaria.
Night^Walker is offline   Reply With Quote
Old August 25th, 2014, 13:09   #48
2footbraker
2footbraker's Avatar
What about removing the vane pump altogether? Although this will delete dynamic timing, you will not be limited by the small vane chambers which provide a fixed maximum of fuel.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old August 25th, 2014, 19:39   #49
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
Are you at max advance and request in software?
If 12mm + DE143 isn't enough and you are willing to have idle problems from loss of dynamic timing control then you need to do an inline pump like Andy. He's running a P3000 with ~250cc output.
Even VP44 would be limited by rpm just like VP37. A modified 12mm P7100 would deliver up to 470cc @ higher rpm than either one. That's more than you need for 500hp. But then, you have no dynamic timing control.
If you still want it to be a street car and you want more than VP37 can give, commonrail is the way. Unfortunately, no one has this figured out yet for the VE!
02 Jetta, 17:1 CR 81mm ASV, block girdle, ported head, custom Colt cam, IE rods, TT springs, Peloquin LSD, Raxles, FueLab pump, 12mm/DE143, Gibonta 5 x 0.018, R32 MAF, NX progressive nitrous, 6+6 turbo, Bilstein PSS9 coilovers, BFI mounts
MKVII GTI 6MT, full build, 525hp daily driver. Soon Xona 8267
loudspl is offline   Reply With Quote
Old August 25th, 2014, 20:47   #50
Yucca
MikkoP did measure 392bhp (469bhp with NOS) with same de143 camplate and 12mm head. Add more air until AFR 18 and EMP<IMP
Old August 26th, 2014, 00:55   #51
Alcaid
Alcaid's Avatar
Originally Posted by Yucca View Post
EMP<IMP
= BIGGER turbo
'03 VW Golf PD130 4Motion Highline - GTB2056VL, 4 bar map, FMIC - 191whp/320wft-lbs @ 4x4 Dynapack
'10 VW Passat 1.6TDI Highline - 2.5" DP (DPF/Cat delete), DP built and software by VVT - 145bhp/229ft-lbs
'83 VW Jetta 1.6TTD - Holset HE200WG-5cm + Custom Holset HX30W-12cm compound, 12mm Dieselmeken pump, Rosten rods, girdle, Ported AAZ head with custom valves, valve springs, Ti retainers, camshaft +++ WIP
Alcaid is offline   Reply With Quote
Old August 26th, 2014, 06:45   #52
kelesha
kelesha's Avatar
On what dyno are these 392bhp ???
And about AFR 18:1.......are you sure about the number 18, thats lean than most of the cars on the market today and will be absolutely smoke free )))
No way 1.9tdi with 8v head to run 392 even 300hp without smoke !!! ;-)
kelesha is offline   Reply With Quote
Old August 26th, 2014, 08:31   #53
Yucca
Totally smoke free 300bhp is easy, AFR >18.
That 392bhp was measured when AFR was ~15.
Dyno gives right numbers. 2.0TDI CR 170 was measured 169bhp etc...
Old August 26th, 2014, 11:08   #54
kelesha
kelesha's Avatar
On 4cyl VP37 engine ??? No way, show me such car somewhere ?
Ok but is that a secret what is that dyno ??? Dynojet, MAHA, SuperFlow, or what ???
Old August 27th, 2014, 12:47   #55
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
Try taking your foot off the dyno's brake
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old August 27th, 2014, 13:09   #56
Alcaid
Alcaid's Avatar
And that last one came from a guy in the UK....
Old August 27th, 2014, 14:32   #57
apomiett
TDI(s): A2 mTDI
Heh
apomiett is offline   Reply With Quote
Old February 9th, 2019, 13:08   #58
WarmStart
TDI(s): TDI
There are factory 12mm P7100 what can flow more than 600cc (with a little modifications) and it controls dynamic timing 10 degrees at full rack travel.
And you can make new pump sprocket what is controlling dynamic timing, there are lot of engines what uses it.
My friend owns common rail nozzles what fit to VE 1:1 even pressure pump is easily mountable, you have to use some aftermarket ECU. Sorry I don't remember on what car he get it but it was a France car. But I think there are lot of engines now (five years later) what parts can use.
WarmStart is offline   Reply With Quote
Old February 10th, 2019, 03:35   #59
Yucca
Tell me more abaut inline pump that have software controlled dynamic timing? Or dynamic timing at all (without those pump sprocket)?
Sure there is VW Crafter 2.5TDI CR injectors that fit to ALH head PnP. But tell me where i can find big nozzles for those bodies?
I think situation is same as 5 years ago. I still think smokefree 300bhp ALH is quite easy to build. Now we have first rotary pump build over 400bhp but it uses compound turbo setup to do that...
Old February 10th, 2019, 11:03   #60
WarmStart
TDI(s): TDI
P-pump uses notched plungers to advance timing. At full rack travel notches will close suction ports earlier.
There are some small factories who can make you small batch off nozzles what ever you need. But much cheaper is extrude honing your nozzles.
camplate dti-vs tdi mk1-83 TDI Power Enhancements 16 October 17th, 2016 07:49
11mm camplate in 10mm pump HO'OLAKO TDI Power Enhancements 77 October 22nd, 2012 13:21
11mm pump camplate papi123 TDI Power Enhancements 1 December 30th, 2010 01:26
WTB DE143 11mm camplate HO'OLAKO Private TDI Items for Sale/Wanted 7 June 11th, 2010 09:01
Larger IP camplate? visionlogic TDI Power Enhancements 4 September 6th, 2007 12:54
Page generated in 0.18699 seconds with 11 queries
[Output: 134.00 Kb. compressed to 112.39 Kb. by saving 21.61 Kb. (16.12%)]
