Old February 11th, 2019, 18:54   #16
Yourbuddysatin
Fuel Economy: 32-35mpg
If you are worried about limp mode, convert to mechanical and ditch all the electronics.
Yourbuddysatin is offline   Reply With Quote
Old February 11th, 2019, 19:14   #17
[486]
TDI(s): 02 golf ALH
Originally Posted by JRoaden View Post
Hi I am not trying to hijack someone's thread but I have a question about permanent removal of limp mode from my 2000 tdi engine as I am using it in a off road vehicle and please don't say Malone's I all but begged for a program and they said fix the problem again I am using this power train in a non standard off road vehicle thanks for any help you can give me
ALH is very easy to 'fix' by deleting codes from the computer's binary
get the $20 silver MPPS cable on ebay and 'find' winOLS software, get an account on ecuconnections forum and search the internal code numbers on there
There are some things that you can't eliminate from the harness like the N75 valve (or at least I haven't figured out how to eliminate them from the program)
What codes is it setting? (not 4 digit P0xxx codes, but the other 5 digit ones that the vag-com spits out)
[486] is offline   Reply With Quote
Old February 12th, 2019, 08:39   #18
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Like I said in our email exchange, it's setting an underboost code which is the reason it is going into limp mode.
You need to fix the problem with the setup that's causing it to underboost..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old February 12th, 2019, 14:53   #19
jhax
Are you referring to this one?
Why do you specify silver?
https://www.ebay.com/itm/SMPS-MPPS-V...gAAOxyYYlRrvUQ
jhax is offline   Reply With Quote
Old February 12th, 2019, 18:42   #20
[486]
TDI(s): 02 golf ALH
the blue one is vag-com, it can't edit anything meaningful
silver one is mpps, it can do anything you want, if you can figure it out in the binary
underboost codes can be removed easily, very common thing to do when going to wastegated turbos. Mine has the underboost and overboost codes removed and the SVBL set higher than the MAP sensor will read. Actually, still using the stock MAP sensor at 45 psi, because the fueling is all MAF controlled on mine.
Old February 12th, 2019, 19:03   #21
Vince Waldon
Vince Waldon's Avatar
Yup.
It's going into limp mode to protect the engine and/or turbo from damage, because the ECU has lost control of the turbo. Worth solving!
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is offline   Reply With Quote
Page generated in 0.12418 seconds with 10 queries
[Output: 76.24 Kb. compressed to 66.89 Kb. by saving 9.35 Kb. (12.27%)]
