Old January 3rd, 2018, 13:26   #16
mk1-83
Fuel Economy: 1:15
Hi i tested thise ebay .360 nozzles theh run first good then they go bad.
Now im buy .310 .280 nozzles from france its good nozzles also test them mine self.
Im in making of new line with dlc coating needle .260 .280 .330 .370 nozzles
Im now dealer from thise nozzles let me know if you need more info im also set then on 1 and 2 inj pressures
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old January 3rd, 2018, 22:37   #17
Jukums
Gibonta is chinese crap for big money. Nozzles are with DLC, but there is problem with that, because DLC also is coated on needle tip. They don't last long and if you don't test them for a long time, then there is possible to melt pistons.
At the moment there isn't good quality big nozzles in market. I only have found 0,300mm nozzles with good quality, who lasts for long time.
But to our projects they are to small. We are searching something like 0,380 - 0,460mm.
Jukums is offline   Reply With Quote
Old January 4th, 2018, 00:29   #18
mk1-83
Fuel Economy: 1:15
Hi yes gibonta dlc on tip is bad milans engine melted a piston by bad nozzle from him.
The dlc coating left off on tip and nozzle streams alot fuel. It didnt close.
Milan it wash his first run with gibonata .360 nozzle on 2 a 3 times sprint they melted piston.
Im saw the picture really bad
Every new nozzle make i test them by let them drive 10.000 km
Lupo 1.9 tdi
300+ HP 500 nm
Old January 4th, 2018, 13:50   #19
turbovan+tdi
turbovan+tdi's Avatar
I don't see a glow plug light? Are all the gp's good? How long do they stay on for?
1984 6.2 Diesel Get A Way van, remote turbo setup designed/installed by me, burning anything that burns.
2003 GSW, 2.0L ALH, Stage 2 Colt Cam, 1756 turbo, auto, silver, 380k-Wife's.
2004 GSW TDI, blue, 5 speed-Malone stage 2, no kitty, aeroturbine muffler, PD150's, PD150 turbo.
turbovan+tdi is offline   Reply With Quote
Old January 5th, 2018, 05:23   #20
Yucca
What is hole size of Firad ASLA150P520 +160% ?
Yucca is offline   Reply With Quote
Old January 5th, 2018, 09:34   #21
sam-
sam- is offline   Reply With Quote
Old January 6th, 2018, 00:53   #22
Yucca
Originally Posted by sam- View Post
0.360
Thanks.
So +120% might be something like 0.330.
Old January 6th, 2018, 03:36   #23
sam-
No problem, the polish guy called cobretti didnt mention 520 HF +120% but santerchips do.
Here is his Facebook : https://www.facebook.com/TuningVag/
He wrote that (actually there is an error, 2 times ASLA150P520 HF +50% with different size) :
ASLA150P520 HF +25% 0.225mm
ASLA150P502 HF +25% 0.240mm
ASLA150P520 HF +50% 0.250mm
ASLA150P502 HF +50% 0.270mm
ASLA150P520 HF +50% 0.290mm
ASLA150P520 HF +100% 0.310mm
ASLA150P502 HF +80% 0.330mm
ASLA150P520 HF +160% 0.360mm
Old January 7th, 2018, 09:59   #24
jabcok20
TDI(s): golf mk1
https://m.youtube.com/watch?v=ZeJyxQm4LSY
0.330 with 11mm gives fueel for 3bar +. Egt 950 and for now problems with boost and soi over 4500rpm.
AFN gtb3576klnrv 12mm
Stock AFN block , CR 17:1 , de143 , pump mod , porthead, GGU gearbox , strenghtened clutch.
jabcok20 is offline   Reply With Quote
Old January 9th, 2018, 08:04   #25
Jukums
Your car seems to be very slow with 3+bar boost, I thnik there isn't enough fuel with 11mm pump head and 0.330
Old January 9th, 2018, 11:15   #26
jabcok20
TDI(s): golf mk1
Propably. I set 3 bar at 5000rpm and i got boost emp near 2:1 so it looks fuel is there or not?
Old February 22nd, 2019, 03:22   #27
toefuk
TDI(s): A4 1Z 1996
ASLA150P520 HF160% are 0,330mm
...measured under microscope...
A4 1Z, GT2052S, PP764+11mm+DE643, KAT out, MAF off-MAP on, 550x140x65, downpipe, 4bar MAP, 2.3 20v clutch
A4 AHH EDC15V, GT1852V hybrid with improved bearings on REA, WZM 0,260
toefuk is offline   Reply With Quote
Old March 1st, 2019, 20:15   #28
D-cappz
What is your injection quantity and injection timing set at?
IQ should be around 3-5mg for best
IT should be around 60 (on the chart between the middle and top line).
I had really hard starts when my IQ was set way too high.
Upgrades:
MK4 4motion swapped 02M ALH 1.92L, Kerma Tune, S7 Turbo, DLC764, Port & Polish, OS Valves, Dual Valve Springs, Colt Cam Stg2, Molnar H-beams, ARL 80mm, Kerma “OMI”, PD150 IM, Kerma FMIC, Kerma CCV, SBC Stg2 Endurance, Wavetrac LSD's, Sigma, custom cluster ColourMFA
http://www.instagram.com/MK4mo_TDI
D-cappz is offline   Reply With Quote
How to video: On car VE injection pump seal replacement video runonbeer TDI 101 376 March 21st, 2020 19:37
New TDI owner here with BIG problems help? Whistle with video and A/C problem. Scottyegg TDI 101 18 July 2nd, 2013 01:20
Video of TDI with only chip and nozzles Bojje TDI Power Enhancements 3 August 8th, 2007 12:24
Changing nozzles on an AGR code engine jeallen TDI Power Enhancements 3 May 15th, 2007 12:32
Page generated in 0.13239 seconds with 13 queries
[Output: 112.59 Kb. compressed to 94.16 Kb. by saving 18.43 Kb. (16.37%)]
