Old February 20th, 2019, 16:18   #1
300k_logician
300k_logician's Avatar
Fuel Economy: 45.6 (6 month average)
Default Myserious Drama with my Coolant T Sensor
Well, here's what's going on:
Here in PDX OR, we have a mild climate, and it's always 40*F and raining. Or at least, 8 months out of the year. Now, it's going under 32*F overnight in the overnight hours.
Basically, my glow plugs (in my '00 ALH 02J Jetta) don't usually need to work this hard. But I've been perplexed as I try to solve my hard cold starts.
-It won't start within a reasonable time frame with only one cycle when it's cold.
-Running the glow plugs 5 times will make things better.
-The issue is not present when the engine is warm.
-The temperature gauge works fine.
I unplugged the Coolant Temperature Sensor:
-The glow plug light acts like my parent's old diesel van, staying on for 20 seconds or so.
-The cold engine starts right up post-glow plug cycle.
-The temperature gauge sits at 0, regardless of actual engine temp.
-When the engine is warm, it will rev at startup (Evidently, a cold engine would need that extra fuel)
So my question is, what do I do?
A) Put Bosch Glow Plugs in. That NKG one is garbage!
B) My relay is bad. Replace it!
C) A coolant temp sensor from NAPA won't suffice! Get something better!
D) If the harness has exposed wires, replace it.
E) All the above
F) Something Else that I have not thought of yet
Thanks for the help.
Thanks for the help, it's much appreciated.
300k_logician is offline   Reply With Quote
Old February 20th, 2019, 17:09   #2
Nero Morg
Nero Morg's Avatar
When you unplug the coolant temp sensor, the glow plug circuit goes into default mode to get it running. It could be your glow plugs are getting on the tired end of things or poor connection at the harness. That four way connector does wear out. Also make sure the contacts are clean on the glow plugs themselves. They can get corroded over time.
Also, don't use autolite glow plugs. I know you said Bosch, but just in case
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old February 20th, 2019, 20:26   #3
STDOUBT
STDOUBT's Avatar
If there was a problem with your GPs or GP relay, you'd have a check engine light at least.
Does your GP light stay lit noticeably longer on the freezing mornings? It should.
Fact is, when that light goes out, the GPs are still glowing. Just sit at "ON", let it go out, and wait the amount of time it would take when the temp sensor is unplugged and try that. 31F overnight tonight!
Also agree with Nero, it would be a good idea to clean the plug ends where they seat in the harness. And BOSCH all the way.
Volkswagen - turning owners into mechanics since 1938
STDOUBT is online now   Reply With Quote
Old February 21st, 2019, 04:12   #4
WildChild80
WildChild80's Avatar
You can change the glow time, it's a temp based map that determines the amount of time the glow plugs glow/light on...you'll need vcds to change it.
I turned my 2000 up a little to help it start in the cold, it's 35 this morning and it'll probably have a 3 or 4 second glow and fire right up.
Really recommend reading the glow plug 101 thread a time or 2.
WildChild80 is offline   Reply With Quote
Old February 21st, 2019, 04:27   #5
oilhammer's Avatar
Fuel Economy: fantastic
There are 1000 threads like this. SO MANY people point to the glow system as the cause of a hard cold start.
As already stated, the glow system is monitored by the ECU. All year round. Hot, cold, makes no difference. The glow system is monitored. If you have a bad glow plug, you'll have an MIL on with a DTC stored. Of all the things these cars are good at, glow system faults are very good at being detected. By far THE #1 reason any ALH TDI ever has its MIL on.
What is probably happening is, an artificial lengthening of the preglow period (by either repeated cycling of the key before starting or disconnecting the CTS forcing the maximum preglow period as its default) is masking some other problem.
Poor engine health (low compression)
Poor injector health (bad spray pattern)
Poor quality fuel
Incorrect cam and/or pump timing (belt not installed correctly)
Or, incorrect temp values being sent to the ECU, in which case no DTC may be generated. If the ECU thinks the coolant is 70 C, it will not command a preglow. This is of course easily checked with a suitable scan tool.
www.cardocautomotive.com
Old February 21st, 2019, 04:29   #6
WildChild80
Pretty sure mine is worn nozzles as I have 308k and probably the ones it was created with.
Old February 21st, 2019, 09:07   #7
Nero Morg
Nero Morg's Avatar
Well it's 30įF this morning, and I'm not far from OP, I'd have to say this is the first morning my car didn't do its typical "a little hard to start" nonsense. But I also noticed that my glow plug light stayed on for 5ish seconds instead of its typical half second. Guess I need to go in and adjust my glow time a pinch
Old February 21st, 2019, 11:14   #8
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
The light just tries to guess when it's ready to start, plugs continue to glow.
Old February 21st, 2019, 13:35   #9
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
Something that drove me crazy on my 7.3 PSD. I think glow time could run up to 90 seconds but the light turned out after like 10? I always wanted to run a light off the glow plug relay to tell how long they were really on (watching voltmeter worked somewhat)
On my older TDIs, I turn the key on, then fasten my seatbelt, plug in my phone, put the coffee in the cupholder, etc. - then start.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old February 21st, 2019, 14:06   #10
WildChild80
My understanding is they do an initial glow and then switch to after glow which isn't as hot but still provides some heat until the coolant reaches a certain temp or when you exceed 2500rpm
Old February 22nd, 2019, 12:37   #11
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Poor quality fuel
Booyaw. Canít add much to that. My money is on late timing.
Itís also possible to lengthen the glow time across the board. Look for a really old post by username Wingnut. ďExtend glow timeĒ something like that.
When you get your hands on a VCDS, check your injection timing in Basic settings 000 on the timing checker and make sure you arenít in the bottom of the graph. Also look at Measuring block 001 with the motor fully warm and verify a plausible reported coolant temp as well as an injection quantity of between 2.0-4.0
If you meet the timing, temp & IQ conditions then go ahead and crank up your glow time by a second or two. I did it to my ~400K mile golf the last winter that I was driving it extensively and it certainly took a lot of the rumble out of colder starts.
runonbeer is offline   Reply With Quote
Old February 22nd, 2019, 12:44   #12
runonbeer
Make sure you didn’t get slipped an H5 battery by some careless shop lackey at some point. The big H7 ALH battery does make all the difference
Old February 22nd, 2019, 19:41   #13
Nero Morg
Nero Morg's Avatar
I checked his injection timing a few weeks ago, it was right on the money.
Old February 22nd, 2019, 20:20   #14
WildChild80
What about static timing? My first bout with starting issues was a cam to crank timing issue.
Old February 22nd, 2019, 20:25   #15
Nero Morg
Nero Morg's Avatar
I didn't check static. He had the timing belt off twice recently doing a normal service. I'd assume it was done right, but you know what assuming gets ya...
Dumped coolant from coolant temp sensor port. baminem TDI 101 10 December 2nd, 2012 11:43
Need help coolant temp sensor and coolant glow plug morenc00 VW MKIV-A4 TDIs (VE and PD) 7 September 16th, 2009 04:30
coolant sensor changed still get intermittent red flashing coolant light jsweatte TDI 101 18 August 23rd, 2009 13:59
Stubborn coolant leak@coolant temp sensor cattlerepairman VW MKIV-A4 TDIs (VE and PD) 3 October 24th, 2008 18:05
coolant temp sensor replace, w/o coolant drain frugality VW MKIV-A4 TDIs (VE and PD) 27 April 13th, 2008 08:00
Page generated in 0.16739 seconds with 13 queries
[Output: 133.54 Kb. compressed to 112.04 Kb. by saving 21.50 Kb. (16.10%)]
