Old February 20th, 2019, 11:02   #3196
Nero Morg
Nero Morg's Avatar
Originally Posted by tom2turbo View Post
Woke up to find my wagon rifled. Lost many small person items, but my favorite tool box remained. I need to inventory so see if any of these great tools were lost. Bummers.
Sorry to hear about that. Portland sucks like that.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old February 21st, 2019, 13:03   #3197
moparvwfrak
moparvwfrak's Avatar
Fuel Economy: 40.6 I know it sucks
radiator failed on the diesel yesterday. 2 gallons in 50 miles. no its not being burned nor is it going into the oil. checked both of those things. i saw it dripping off the front bumper when i looked. yay...... at least my 2slow still works right.
2 99.5 jettas. One TDI one gas.
1 91 cabriolet
1 93 Cabrio (parts for the Cabriolet)
2 93 BMW 325i
1 81 320i
moparvwfrak is offline   Reply With Quote
Old February 21st, 2019, 13:17   #3198
deathtrap
deathtrap's Avatar
bought a relay 109 and an oil filter for it along with an oil filter for the MK2.
deathtrap is offline   Reply With Quote
Old February 21st, 2019, 13:40   #3199
tdidieselbobny
tdidieselbobny's Avatar
I finally shoehorned an H8 battery in, as the battery from the gasser Jetta wasn't cutting it. Got the H8 from Walmart a week or so ago for around $81,it was a "used" one that had date code of 11/18 on it. I ended up cutting out the lower bottom corners of battery tray. The battery doesn't go under the lip, but I got the front lower hold down and bolted. I used some zip ties to hold the fuse pack to top of battery. Fires up nice and easy now. When weather breaks, I've got a list of to-do items on it.
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten:mad-'15 Silk Blue Golf Sportwagen w/DSG, 43k miles....'16 Kubota BX1870 MMM/FEL, 260hrs-And now an '03 Jetta TDI 5spd w/ 443k,RC2,Sprint 520's,Dieselgeek short shifter , totaled 10/13/19 by a stupid deer, back alive 11/4/19....
tdidieselbobny is offline   Reply With Quote
Old February 23rd, 2019, 04:57   #3200
Rrusse11
Dropped my IQ a point to 8.0. Wow, FE will drop a bit I'm sure, but
performance is impressive, no smoke. I'll take the hit for the bump
up in response and power after an 80 mile round trip last night.
RC Stage 4: 11mm pump, 17/22, .230 nozzles, 3barMAP,EGR Delete, PD150Intake,SMIC,2.5" Exhaust: Koni Sp Reds, Wagon Springs, ~1"/2"lift:VR6 fr swaybar, Top strut & rear tie bar: 215/55ZR16 GMax AS05's, 10mm/20mm spacers, 35# @: skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: : VR6 fr, TT rr Brks
Rrusse11 is offline   Reply With Quote
Old February 23rd, 2019, 11:50   #3201
deathtrap
deathtrap's Avatar
drove it to visit my uncle.
got closure on his wagon.
i had overfilled it with oil and blew the engine.
explains why it was running rough. two cylinders dropped compression.
he is swapping a spare motor in, going 17/22, and throwing in a south bend clutch in.
Old February 24th, 2019, 00:08   #3202
hey_allen
Tie rods on both sides, after the new outer on the right split the boot within 6 months, and the right inner threads we're already damaged.
When the left started to develop some play, I pulled the set.
While I had the car in the air it was easy to knock out the oil change as well.
I did find out that setting the toe-in by counting threads is nearly useless when changing tie rods, but an alignment brought it back into adjustment easily.
hey_allen is offline   Reply With Quote
Old February 24th, 2019, 09:08   #3203
sriracha
Fuel Economy: 40mpg+/-
Took my wagon on a little adventure in Big Sur. Drove it 5 miles out a dirt road at the top of the mountain. I was a little worried about clearance and traction on the muddy parts, but the little diesel just pulled through everything like it was no big deal. I had been considering lowering springs, but after yesterday’s adventure, I like the ride height and articulation of the stock springs. I’m tempted to buy some larger BFG dirt tires for my steel wheels, to swap when needed.
sriracha is offline   Reply With Quote
Old February 24th, 2019, 09:27   #3204
Rrusse11
Hmmm, your uncle sounds like quite the handy guy.
Old February 24th, 2019, 17:29   #3205
Caddy 16v
Caddy 16v's Avatar
Retired the Jetta for 3 months or so, bought a 2005 Legacy GT wagon to drive in the winter and have more fun.
2000 Jetta, mufflerectomy, Evolution Atlas skid plate, OEM xenon reps retrofitted, Hella Micro DE, HFLOX Warp 3 nozzles, 3 bar map, Malone Stage 5 Custom, Euro 17/22, DC Stage 4 clutch, STAGG suspension, Curt hitch, Auber EGT and NSP boost gauge, Hella Sharptones, Rally Armor mud flaps, 1.8T pancake pipe, upgraded SMIC, VAG-COM, all offroaded out
2000 Golf, JSP Armadillo skid plate, limo tint (Sold)
Caddy 16v is offline   Reply With Quote
Old February 25th, 2019, 15:22   #3206
tdidieselbobny
Is the GT a rare 5 speed?
My son likes them... on the VW front, I found a battery tray from a Golf to swap into the Jetta so the recent H8 battery can be held in better. Now trying to figure out if first cold start of day hard starting is due to the code for bad glowplug or maybe the IP, haven't had warm enough weather to rule out glowplug yet...
Old February 25th, 2019, 18:11   #3207
sriracha
Washed all the mud off of my wagon.
During the process of washing, I chased down a leak that I notice during the recent rains. In the back right, top of the hatch near the hinges, the rubber tube that carries the wiring from the body to the hatch was dislodged from the plastic lip and allowed water to drip inside. I was able to get the grommet seated on the lip and tested it with the hose. Seems to have resolved the leak.
Old February 25th, 2019, 18:31   #3208
BakoTDI
BakoTDI's Avatar
Dropped off my Jetta to get a new clutch! SBC stage 2 Daily. Once that is done, new nozzles and Stage 3 Malone tune. But today I replaced the serpentine belt tensioner.
99 Canyon Red MK4 Jetta, 5-spd, South Bend clutch Stage 2 Endurance, Firad P502 nozzles, Stage 3 Malone Tune.
BakoTDI is offline   Reply With Quote
Old February 25th, 2019, 20:17   #3209
TornadoRed
TornadoRed's Avatar
There is a product called JB Super Weld which will hold that grommet in place. And you may find a use for what's left over.
'03 Golf with 809k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat fuel filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, Delvac1 Plus 2 other '03 TDIs
Become a TDI Club Contributor. http://forums.tdiclub.com/payments.php
Old February 25th, 2019, 21:24   #3210
romad
romad's Avatar
Actually, any brand of cyanoacrylate adhesive ("super glue") should work.
I used the original JB Weld to repair a notch worn into the metal latch loop on my Miata's hood. Funny how the latch wore away the metal through vibration but didn't do it to the hardened JB Weld filler!
The fleet:
romad is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
I saw a TDI CC today in Denver today 9/14/2012 rotarykid Sightings 2 October 2nd, 2012 18:30
MKIV 6 disc, Yakima Q103 clips, MKIV 4 spoke airbag Reifenberger Private TDI Items for Sale/Wanted 3 May 21st, 2012 15:42
What have you done to your MkIV today???? Kymerik VW MKIV-A4 TDIs (VE and PD) 3 October 7th, 2009 06:24
FA: MKIV Jetta Original Floor Mats (Ends Today) jtroyce Private TDI Items for Sale/Wanted 0 October 29th, 2002 05:19
Page generated in 0.23352 seconds with 13 queries
[Output: 139.05 Kb. compressed to 117.08 Kb. by saving 21.97 Kb. (15.80%)]
