Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old January 17th, 2019, 11:13   #1
Moggycj
TDI(s): 05 passat
Default Transmission fill/drain plug socket.
Hi wondering if anyone in London has this socket I could borrow to add fluid in my gearbox. Has a leak and itís staring to back a noice. Help would be Appreciated. thank you. https://www.google.ca/search?ei=dc5A...CMFoFhg4KXkRM:
Moggycj is offline   Reply With Quote
Old January 17th, 2019, 18:51   #2
mogly
Princess Auto has decent quality 12 pt socket sets available.
mogly is offline   Reply With Quote
Old January 17th, 2019, 21:32   #3
Moggycj
TDI(s): 05 passat
Thank you I called parts source and it was $50 for the kit but my funds are really tight right now. Laid off from work and just looking to see if someone had one I could borrow. Want to get fluid in before itís to late. Was maybe going to see if I could access though breather tube but from looks of pics the breather hole is between the trans and dog tunnel.
Old January 18th, 2019, 11:43   #4
mu3098
Are you sure you are looking for the right socket. The automatic transmission on the 2005 passat uses a regular 17mm allen / hex bit for the fill plug. Here a link for the proper fill procedure https://www.myturbodiesel.com/wiki/a...ssat-and-audi/
mu3098 is offline   Reply With Quote
Old January 18th, 2019, 11:55   #5
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
If its a 17mm hex, you can use a wheel bolt to remove it. Simply use a 17mm wrench and the extra part of the wheel bolt that extends past the wrench will go in the drain plug.
Moving? Need boxes?
Go green and check out FROGBOX.com
Old Ride (2000 Black Sedan): Gone
New Ride: (2003 Silver Wagon): Malone Tuned, T4 injectors, 11mm pump, 2.5" Magnaflow cat back, PD150 intake, OMI, Wingnut SS, ERF 6 speed, Bilstein TC Sport susp. w/GTI springs, Neuspeed RSB, Santa Monica's, Autometer Cobalt Boost & EGT, MFA Sport cluster, GLI Leather seats, SS vacuum lines, AVIC Z3 Nav and I still get 4.5L/100km (I got 3.9L/100k on a tank once)
Some handy 'How to's'
Wingnut is offline   Reply With Quote
Old January 18th, 2019, 19:20   #6
Moggycj
TDI(s): 05 passat
Sorry forgot to mention I have a fhn 5spd.
Old January 20th, 2019, 18:17   #7
QuickTD
The FHN uses a regular 17mm allen key in the fill plug but the drain plug in the bottom is a security triple square, (triple square with a hole drilled in the center). I usually just haul the security triple square out with vise grips and replace it with a regular 17mm hex plug from some transaxle in my junk heap. After all these years and all these swaps, I have still not purchased the proper tool...
QuickTD is online now   Reply With Quote
Old January 20th, 2019, 21:20   #8
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Another option is to remove the security feature and use a standard triple square.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old January 21st, 2019, 08:44   #9
imo000
imo000's Avatar
Fuel Economy: Good enough
Or wait until fund are available and buy the proper bit for it. It's not like the transmission is going to explode if you wait a little more. I still have the same oil in my FHN that the transmission came with when I bought it used 4.5 years ago. Unlike automatic transmissions, manuals are not that finicky when it comes to regular oil change interval. There oil doesn't get as dirty because there is no friction material to wear.
imo000 is offline   Reply With Quote
Old January 24th, 2019, 10:24   #10
Moggycj
TDI(s): 05 passat
Fill plug on mine is also triple square. Got the proper tool. Pulled fill plug to stick my finger in the hole. And brass fillings not much oil in it. Filled it up to see oil drain out the bell housing ��. My thoughts maybe a bad input seal?
Old January 24th, 2019, 15:14   #11
Uberhare
Uberhare's Avatar
TDI(s): Too many.
You filled it to the bottom of the fill plug and it immediately leaked out the bell housing? That is not good. Something must have perforated the case. You'll likely have to pull the gearbox at minimum to investigate.
The good news, with the manual swap, you don't even have to drop the subframe anymore! The last B5 manual, it only took me an hour to pull.
Old January 25th, 2019, 06:02   #12
imo000
imo000's Avatar
Brass filings and not much oil? That transmission needs to come out and taken apart. Sounds like it was driven without enough oil.
Old January 27th, 2019, 13:02   #13
Moggycj
TDI(s): 05 passat
I think so to I had issues last year with the third gear not going in to gear with out grinding. Unless I was to make the shift at the right rpms. My thought is it’s from a bad Synkro. I’m just waiting on my friend to put his hoist up so I can get the car in the air and pull the transmission. Then maybe try and source a new one. Love hate relationship with this passat. I came to appreciate the torque after driving my friends matrix the other day
Old February 17th, 2019, 22:38   #14
Moggycj
TDI(s): 05 passat
Well I got some time and a spot to bring the car in to pull the transmission. And well get it out to find a big hole blown out in front of the ring gear. 😥. Made a phone call to Bruce and he was able to source me out the transmission 2 km from where I was. Score. Thanks again. Got it in the car and seems to be working great now. And Surprisingly wasnít too painful to change eight hours maybe going at it softly.
Manual Transmission Drain/Fill Plugs jekl843 VW MKIV-A4 TDIs (VE and PD) 7 March 5th, 2018 22:13
17mm Hex key/socket for gear box drain/fill plug 3800rpmDiesel TDI 101 36 May 27th, 2012 06:43
Manual Transmission drain/fill plugs chippy TDI 101 4 November 7th, 2008 08:30
Size of the Tranny fill and drain plug? kilo69 VW MKIII-A3/B4 TDIs 1 July 18th, 2008 13:23
Where is the 5spd drain plug/fill hole? TDI77 TDI 101 10 February 7th, 2006 13:15
Page generated in 0.15562 seconds with 13 queries
[Output: 119.27 Kb. compressed to 99.76 Kb. by saving 19.52 Kb. (16.36%)]
